Merco avatar
every time I try to adjust the altitude screws they don't move, preventing me from doing an accurate polar alignment, clear skies to y'all.
Olivier Bernard avatar
What you mean you have to take one out and the another one you turn
Terry Maurice avatar
Was it previously working, and now no longer is? Both bolts have to be used at the same time, one tightens while the other loosens.
Christophe avatar
[pre]Either the threaded rods are threaded or the threading of the mount is damaged.[/pre]
Merco avatar
Terry Maurice:
Yeah I've already tried but nothing they don't move
Christophe avatar
[pre]You should check the two screws to see if their threads are damaged.[/pre]
Bob Lockwood avatar
Can you loosen both adjuster screws ?
If so, can you back them off, say 1/4" 4-5mm and move the mount by hand ?
If not, the bolts holding the mount to the tripod/pier may be too tight.
Merco avatar
both are like this, but even trying to apply a light pressure they don't move an inch
Bob Lockwood avatar
Did you try what I said above.
Merco avatar
Bob Lockwood:
*Yeah, I tried but still nothing, the screws are not damaged
Christophe avatar
[pre]If it is not the screws that are broken, it is certainly the internal thread of the frame.[/pre]
Merco avatar
Christophe:
probably, in that case, I will go regardless of someone who can help me, thanks to everyone and clear skies!
Bob Lockwood avatar
Just curious, what mount are you using.
Never mind,  HEQ5
Merco avatar
Bob Lockwood:
HEQ5 PRO bought a few months ago.
Bob Lockwood avatar
Could this be the problem.
Merco avatar
Bob Lockwood:
No, I also tried with a little lubricant but nothing, now as soon as I have time I'll take the mount to the service center, I don't want to cause further damage, thanks anyway
Merco avatar
update: I managed to fix it somehow, I'll do some tests tonight, thanks everyone for helping me
Tommy Blomqvist avatar
Retract both screws and see if you manually can move the Alt-axis on the mount.
If it is too hard you should loosen the tension on the bolts on that axis.
Merco avatar
Tommy Blomqvist:
I managed to fix it, thanks anyway!
Discusses astronomical mount adjustment; may address altitude screw issues.
28 days ago
