Scope slips in mounting rings.
6 replies175 views
Peter Robertson avatar
Hi everyone. I have a new WO FLT 120. So far everything works very nicely and very happy.
 However if I point the scope vertically, for example during balancing on the mount, the OTA tends to slip in the saddle rings … which is a bit scary and leaves me wondering if it might fall out during a session. The mounting ring knobs are as tight as I can make them by hand, which seems to just hold it, but over time it will start slipping again. The brackets that the knob's secure seem to be metal to metal, so it doesn’t look like it can be tightened further.
Just wondering if this is a general problem and what people do about it? As I mentioned it’s new, so this shouldn’t be wear and tear on the bracket lining. This is my first telescope ( I am upgrading from camera lenses ) so sorry if it’s an obvious solution.
Thanks for any suggestions or shared solutions!
peter
Respectful Engaging
Rubber bands on the scope side.
Miguel T. avatar
FLT 120 here, same problem. Fixed that 2 years ago with a small strip of adhesive velcro. All it need is just a bit of resistance to not slip.
Bob Lockwood avatar
When I make my own rings, I line them with this sticky-back Felt. Works great, very smooth, very thin, very clean, very safe.
But I agree with Andrew, this should not happen in the first place.
Andrew avatar
Sorry I don’t have anything useful to add.
but that’s crazy that has not been fixed…….. scopes should absolutely not do that.
Miguel T. avatar
Andrew:
It shouldn't do that but it's also not THAT bad. Happens only with the scope pointing up during flat sessions on cold humid nights with condensation on the tube, and it's a very slow slip. Very easy to fix.
Thanks for your helpful comments and fixes, I agree the slippage is not great and can be stopped with an extra hard twist of the knobs, but it seems odd that such fixes are needed straight out the box.
Color Palettes
Just wondering how much everyone else has thought about the color palette's for narrowband imaging. I seem to gravitate to the Huble Palette but have started looking at it a bit more when processing. I did a compare recently just to check it out....
Discusses telescope hardware issues, not narrowband imaging processing techniques.
Jun 15, 2023
A versatility of the Askar FMA230 rings.
Hi, Everybody interested in the Askar FMA230 had to see threaded holes on each of the four sides of the rings. I decided to use them all. All my scopes have the ZWO EAF attached, so I ordered the Deep Sky Dad's kit for the EAF as well. It's p...
Discusses scope slipping in mounting rings; directly relevant to ring attachment problems.
Jul 22, 2023
Esprit 120 Slippage / Sesto Senso 2
Hey Guys, some time ago I was quite astonished to hear that there are tak toa users that support their focusers with rubber bands to get rid of slippage. First time hearing that people support their premium scopes with rubber bands I thought, that ca...
Discusses slippage issues with scope mounting, directly relevant to OTA slipping problem.
Jan 19, 2026
Trying to make a decision on selling my WO FLT91 for a WilliamOptics FLT120
I currently own a William Optics FLT 91 and am considering selling it to highpoint scientific in order to purchase a William Optics FLT 120. I am wondering if the change in aperture and focal length is worth it. I am not into SCT’s mostly due to weig...
FLT 120 ownership experience directly relevant to upgrade consideration.
Aug 24, 2023
Hello from South of France!
Hello from the South of France from a place where the "Perrier" comes out of ground ! (sorry for my approximate english, but I trie! ) So, i am Fabrice, 50 years old, passionate for astronomy since my 7! … In the first time, I observe...
Author has astrophotography experience; scope mounting issues relevant to equipment setup.
Dec 26, 2023
