Dan R avatar
Hello everyone, I'm looking for a bit of advice on whether or not the level of noise I'm seeing in my images is too much or not.
I've recently been going after IC-63 (Ghost of Cassiopeia) and I've tried to push on the Hydrogen-alpha in the exposures.
For reference:
  • Telescope: William Optics Zenithstar 73
  • Camera: Player One Poseidon-M Pro
  • Filters: Optolong Hydrogen-alpha 3nm
  • Gain: 125
  • Sensor Temp: -10c
  • Exposures: 78 x 600", totalling at 13 hours
  • Dithered every two subs
  • Guiding averaged between 0.4"-0.8"
  • Final stack set to 1x drizzle (Drop Shrink set to 0.8)
  • Calibrated with 30 x darks, 30 x flats and 30 x dark-flats
I see posts quite often here where users share data and I often see comments like "the data is really clean" or "barely any noise" however when I take a close-up look at my images, I don't think I can say the same.
Here's the final Ha stacked sub with BlurXTerminator ran over it and the STF applied via HistogramTransformation:
Zooming into a random area with a bit of nebulosity to the left shows the noise:
Perhaps I'm being too critical, I'm not too sure, so I thought I'd ask here to see what others think: is this acceptable? Can you see anything I'm doing wrong from my description above? Is it just a question of needing further integration time?
Any advice or recommendations would be welcome.
What do you expect from 3nm passband and 73mm of aperture @ f/6? The object is intrinsically faint and you aren't even capturing the whole emission/reflection spectrum.
Dan R avatar
I suppose I don't really know for sure what to expect, hence my post. Sounds like I'm expecting too much of my equipment by the sounds of things!
Craig Towell avatar
Doesn't look too bad to me, the STF is a bit severe so that isnt helping, try to stretch it normally (in your normal manner) and see what it looks like, get it to a point you're happy with it.  I'm assuming you have NoiseXterminator? What does it look like after running that?  I wouldnt bother with further integration time, youre already at 13 hours and you would need to go a lot lot longer to get appreciable benefits in the noise.
Also dont forget this filter lets barely any signal through so it's always going to look on the noisy side.
Helpful Concise Supportive
Ian McIntyre avatar
That's pretty close to what I usually achieve with either of my cameras. Both of which are IMX571 sensors. Though with the seeing in my locale I never shoot longer that 360 second subs. Even that is pushing it most nights. You might try trimming the gain to 100-101. The other thing that may be having an effect on my subs is the offset. I am waiting for a clear night to mess around with that. I presently set to 25, but apparently some allege quality results with offset in the 100-200 range. I've even seen a claim of 700+.
Tobiasz avatar
Looks okay to me, especially with this setup.
It doesn't look like anything the standard noise reduction tools won't clean up.
Well written
Lynn K avatar
It all depends on what your plans are for the final image.  Do you plane to print a 2ft X 3ft poster?  if so, then maybe too much noise.  Are you going for an IPOD?  If so, then maybe too much noise.  If on the other hand, you are only going to post on Astrobin, then it's probably fine.
Lynn K.
Dan R avatar
Thank you all for your replies. I think in hindsight, I was just expecting a bit too much from my set-up.
I think I might try a different gain setting in the future just to see if that changes anything.
Whilst I use NoiseXTerminator, I've found that ever since the last update, the image ends up with a weird posterised effect and I end up needing to revert back to the previous AI version and even that sometimes has the same result. Might be a problem with my hardware though as sometimes when I completely close PixInisight then reopen and run NoiseXTerminator again, the image turns out ok, perhaps a caching issue of some kind.
Anyway, for those interested, I reached a final image that I'm fairly happy with in the end: https://www.astrobin.com/3qyrs3
Thanks again!
Dunk avatar
Dan R:
Do you NoiseX before or after stretching? Before the most-recent update, I had to do it after a stretch as I would get weird artifacts otherwise. The latest update has fixed this for me though. Maybe try switching to whichever you are not doing and see if it helps.
Well written Concise
Alex Nicholas avatar
It looks more noisy than I'd expect for 13h of integration… but then I've never shot this target to know how dim we're talking about - however, I can guarantee you this, any of the noise reduction techniques will have this looking STUNNING in no time at all…
I wouldn't be too concerned.
Oh, another thing you've not mentioned… What are your sky conditions. Despite the 3nm Ha filter, I can assure you that if you're in B8 or B9, you won't avoid noise from sky background/skyglow in your images.. Ha and SII won't be as affected as a OIII filter will, but you will still CLEARLY notice the difference… My setup in dark skies with a full moon up produces cleaner data than when I'm in Bortle 6 in my backyard on new moon… Food for thought.
NGC 2011 (LMC) processing issues
Hi all, I have been imaging the LMC, specifically NGC 2011 and 2014 for the last 4 nights, and have collected about 12 hours of data. I am using a ZWO 1600MM with ZWO Ha and Oiii filters (low quality i understand). They are mounted on the Sharpstar A...
Directly relevant for assessing acceptable noise levels in collected data.
Dec 18, 2023
Star Halos and star "+"?
Hello everybody so last night i decided to shoot the Ghost Nebula and Iris Nebula in one frame wiht my redcat 51 and Asi183MC Pro. Now, i only got a little above an hour of integration time but i wanted to ask, is this wierd + artifact that i see on ...
Noise level assessment relevant to evaluating image quality and artifacts.
Oct 14, 2023
[RCC] Advice on Eagle and Swan nebulae mosaic
Hi everyone. I've recently published a 2-panel mosaic of the Eagle and Swan nebula, capture with my Esprit 100 and ASI 2600MC OSC. I think that for the most part, I like the result. The detail is nice, and 8h plus in each panel meant I could push...
Author discusses noise management in stretched images; candidate addresses noise level concerns.
Jul 27, 2023
Struggling with Corona Australis - Would Appreciate Your Expertise!
Hello everyone,I hope this message finds you well. As an amateur astrophotographer who ventured into this mesmerizing realm a few months ago, I've been on an enriching journey filled with steep learning curves. The expertise and insights shared o...
Quality assessment of amateur astrophotography results and image evaluation.
Oct 10, 2023
OIII Aberration Question
Hi AstroBin hive mind, Question for you all. I've been imaging the Flying Bat and OU4 from the UK in 'nautical' night/twilight (yes I know, ill advised!) and I'm getting the below aberration on this bright-ish star (think it is HD 202...
Discusses image quality assessment including noise in stacked astronomical observations.
Jun 20, 2023
