Dovetails just informational
4 replies178 views
Clayton Ostler avatar
I want to share something that literally was unclear to me for over a decade. Yesterday I had to sort out the terms to help a friend buy the right parts to mount a guide scope and realize this info might help other newcomers too.
There are generally 3 universal sizes of what the industry calls (dovetails).
The term dovetail was and is confusing in this hobby (at least for me) and then it gets mixed in with "Universal" and Base/Saddle/Shoe when talking about the female/base they connect to.  which even causes more confusion.
Synta Style. (Often used for finder scopes and accessories, also used for many smaller guide scopes). This is the size of the small mounting shoe/base that is often included on top of telescopes to put in a finder scope, or attach a small guide scope, this size is also what is included as the default "dovetail" that comes wiht an asiair,  and is found on many laser pointers. The mounting base for Synta style is usually pretty small and most often is square shaped. You can pickup additional bases for synta size dovetails bases for less than 20$. I have never heard the base of a Synta dovetail described as a "saddle" but I don't pretend to know everything on this topic.  I see a lot of "Where do I get the small shoe/base/mount for my finder scope or guide scope" or "I need a dovetail that connects to the accessory base on my scope or handle", usually this is someone looking for Synta style adapters and dovetails.
Vixen style. This is what many small to medium telescopes are mounted on by default. It is wider that the Synta and therefore better for larger weight. These is the most universal as far as a telescope mount saddle compatibility. I think generally this is what most people think of when they think of an Astronomy Dovetail.
Losmandy style (often called D size). These are about twice as wide as the Vixen style. These are great for many things but generally are the saddle and base for telescopes. For many years I thought that this was used for higher end scopes, heavier scopes or scopes mostly focused on astrophotography. I still personally think this is true, but it is not a rule or standard by any means. These dovetails typically cost the most of the 3 mentioned here.
In my early days of this hobby I purchased a couple of these only to find out my mount didn't support them so they were expensive paper weights. I personally have only ever used these to mount a actual telescope, it seems like overkill for finders guide scope, accessories etc. But there's not reason you could not use this for those items as long as you have a saddle to connect it to.
Keeping.  these 3 straight will save you a lot of headaches.  I know there are other "lesser known" or "less common" versions too, but I am trying to keep this as simple as possible for newbies and simple minded guys like myself.
Last part, the hole patterns and sizes in these dovetail bars and their associated  bases/shoe/saddles is not NOT universal. This has burned me for a few hundred dollars over the last decade, make sure that you know the bolt/screw size and patterns if you intend to connect something directly to the respective dovetail.
For years I didn't know the term (Synta style) and would Google looking for a guide scope base or accessories bar etc. And had no idea if it would work. Example, telescope mount "accessory bar or shoe" is really just saying Synta style/size shoe or base.
For years I would go on ebay and buy a cheap Vixen Style dovetail bar, only to find out it didn't have the bolt holes needed to line up with telescope rings or some specific item I hoped to mount directly to the bar.
I hope this is helpful to someone, somewhere.
Clear Skies.
Kyle Goodwin avatar
Clayton Ostler:
There are generally 3 univeral sizes of what the industry calls (dovetails).
The term dovetail was and in confusing in this hobby (at least for me) and then it gets mixed in with "Universal" and Base/Saddle/Shoe when talking about the female/base they connect to.  which even causes more confusion.
For years I would go on ebay and buy a cheap Vixen Style dovetail bar, only to find out it didnt have the bolt holes needed to line up with telescope rings or some specific item I hoped to mount directly to the bar.
I use Losmandy-style (D-style) dovetails exclusively, on both top and bottom of my scopes, and I mount accessories on them as well.  The extra heft of the larger size dovetail adds extra rigidity to the system even if it isn't necessary for the weight of the accessories themselves.  Even when I have nothing at all mounted to the top of a telescope I still have a Losmandy dovetail mounted to the top of the rings/tube as the case may be.
Well written
Clayton Ostler:
Clear Skies.
It's not hard to drill holes in aluminum...
Marko avatar
Synta style is exactly what I was looking for a few days ago, but did not know the name for, when I got my new guidescope which was sold to be compatible with standard finder shoes and came with a vixen bar.
I ended up printing my own dovetail for now, since 100mm long ones seem not to exist.
Oscar H. avatar
didn't know about the Synta one, thank you
I never knew the name for it
Beginner Telescope Recommendations
My friend wants to buy a telescope and I was hoping to get some recommendations as he is a complete beginner and doesn't know how to properly use a telescope. He wants a normal telescope and not computerized as he wants to first observe before he...
Helps friend with telescope equipment selection and understanding components.
Sep 23, 2023
Just when you think you know what you're doing...
Just when you start to think you know what you're doing, the universe smacks you around a little to keep you grounded. First off, this isn't a great image of M106. It's what I could manage with too few subs. It's a total of about 80 m...
Dovetail information irrelevant to imaging technique or data collection issues.
May 10, 2023
Beginners corner
I would like to see an area for people new to this (for me it has been 2 nights). I have a few images I would like to share but compared to almost everything on the site I would be embarrassed to make them public. I was glad just to see anything.
Informational about dovetails, useful foundational equipment knowledge for beginner.
Jun 8, 2023
Samyang 135mm - advice on how to setup
Hey, I have found myself a cheap Samyang 135mm f/2 lense. Now I just need the rest of the “rig”. I have my EQ6-R Pro mount and ZWO 2600MM camera. What’s the best options for attaching lense etc. to my mount and what do you all do for Auto focusing? A...
Dovetails explanation relevant to attaching lens and camera to mount hardware.
Aug 8, 2023
Attachments for the EAF
I am setting up the William Optics Redcat71 Telescope. Has anyone used one of the following attachments for the EAF: WO REDCAT 71 ZWO EAF DOVETAIL KIT or BuckeyeStargazer ZWO EAF Mount for William Optics Redcat71 Telescope? Are there any other option...
Dovetails informational — relevant to understanding dovetail attachment options.
Nov 20, 2023
