Strange grid / stains pattern in background
6 replies207 views
Konrad Krebs avatar
Hello everyone,
i get a strange pattern in the background of my final stack.
I used a ZWO ASI 183 MC Pro at -20°C, gain 50, 30s per shot, 1800 shots in total. Dithered every few shots, blinked through all images, nothing obvious.
Flats, darks and dark flats, all in WBPP. The individual images all look normal, even the master flat and master dark are completely normal. does anyone have any idea what the problem could be?
Blue Smith avatar
No promises, but I've had similar issues before. Try stacking without your bias frames and see what happens.
Alex Nicholas avatar
This can also happen if you're drizzling the data with not enough sub exposures or insufficient dither settings. Drizzle works of a weighting map, and if you don't have enough subs you get better weights in some areas than you do in others, resulting in a mesh pattern appearing throughout the image.
If it was a calibration issue, you should see it on the images in the 'calibrated' folder that is output from WBPP. If you're not seeing it on individual calibrated subs (though it will be harder to notice)…
Konrad Krebs avatar
Thanks for your suggestions. In the meantime I tried different ways and also made another observation.
Blue Smith:
Unfortunately this did not do the trick. I also tried to only stack different smaller subsets, with the same result
Alex Nicholas:
Also this idea did not work out unfortunately. I tried to stack without drizzling, with the same result. And there were absolutely no signs of this pattern in any of the calibration frames. I tried stretching them very much and still no sign. I have about 1800 subs, so this should be sufficient amount.
What I tried next:
I took the data over a total of five nights and photographed a different object in the second half of each night. So now I tried to stack the data from the second object with the same master calibration frames. The result: no visible pattern.
I'm really at a loose end. I can't see any recurring pattern in the individual calibrated raw images either.
Hornisse avatar
I have the same issue, with Canon 600D DSLR
Ali Alhawas avatar
Konrad Krebs:
Hello everyone,
I think its a calibration issue.
I didn't have this before but try different combination of calibration settings also check your calibration frames.
CS!
Yours is different from his. In your case it is walking noise, so the best cure for you is to dither (say 10 pixels) every now and then.
Checkerboard pattern after stacking and star removal?
Hi all, This morning I stacked together some WIP data collected so far just to see how it's looking. No processing other than: - 45x300sec stacked with darks only (no flats, dark flats) Stacking with WBPP and in DSS produces the same result - Dyn...
Grid/stains pattern matches author's mysterious background pattern issue.
Oct 24, 2023
ZWO ASI 2600MC producing doughnut artifact in center of images
Hello everyone, I have had a ZWO ASI 2600MC for about a year now, and I have noticed that all the images I have taken with it since then have a strange artifact in them. Basically, it looks like a doughnut in the center of the image. This is particul...
ZWO camera artifact; similar sensor model experiencing unexplained pattern issues.
Nov 27, 2025
Problems with ASI2600MM and/or ASIair
Hello, does anyone have ideas or experience with this? Half of last night's frames look like this. I then restarted the ASIAIR and did flats. Some of them look the same or have artifacts. But not all. I did a test run at home (3 x 60 images, cool...
Similar cooling temperature and grid pattern artifacts with ZWO ASI camera model.
May 14, 2023
Gradient in dark frames
Hi everyone! I recently bought the Player One Poseidon C Pro camera and after a very long period of cloudy nights it finally cleared and I got to try it. When taking the lights everything was normal. When the sun rose again the pictures got very satu...
Gradient issues in dark frames; directly relevant to master dark problems.
Mar 5, 2026
Dark bands at top and bottom of Minicam8M
EDIT: QHY support responded with the following statement: “We can basically confirm that this phenomenon stems from the light-gathering limitations of the Minicam8M sensor structure at extremely fast focal ratios (F4), rather than from mechanical obs...
Dark bands artifact in stacked images; similar pattern anomaly in final stack.
Nov 8, 2025
