Flat panel from Deepskydad it flickering when it connected to the Eagle 5s
2 replies77 views
Dumitru Irizan avatar
Hello,
My flat panel from Deepskydad it flickering when it connected to the Eagle 5s.
I power it with 12V 3A from EAGLE 5S. When I power this flat panel independently of the Eagle, directly from a dedicated 12 V power supply, it works perfectly.
The Eagle is connected to a Bluetti battery that delivers a constant 13.3V. Has anyone had a similar situation? or does anyone know how I could fix the problem?
Dave Erickson avatar
Yes, not with that brand, but with other EL flat panels when they are under powered, ie. not enough power…
I realized this too, I tried changing the Eagle port output from 12V 3A to 12V 5A, and still no results. The voltage is not possible to change.
ASIAIR Mini Amp Problem
Hello, I'm having trouble with my ASIAIR Mini concerning power supply, especially Amps. Recently it's behaving very strange, and the internal measurements show 12V, but only 0.1A. After seeing that, I tried multiple PSUs (2 official ZWO 12V5A...
Power supply amperage issue similar to flickering problem with Eagle 5S.
Aug 20, 2025
