Weight of Askar 130 PHQ Focuser
12 replies226 views
Jerry Gerber avatar
Might anyone know what the weight of just the stock focuser is for the Askar 130 PHQ refractor?
I'm replacing it with the Moonlight WR3.5, which weighs 8 lbs.
Jerry
Brian Sweeney avatar
It's just slightly over 4 pounds. I replaced mine with a WR3.0 nitecrawler
Jerry Gerber avatar
Thanks Brian!
Are you happy with the Night Crawler? Any reason you went with the 3.0 rather than the 3.5?
Jerry
The nitecrawler is amazing and built like a tank! I already had the 3.0 from my previous, 115mm telescope. I confirmed with Ron if it would work on the 130 and it does!
Previously, I had the ATIK 16200 camera with 50 mm filters and now have a Player One Zues camera with an even larger sensor and the same filters, so I feel like I would have noticed any issues by now if it was too small.
Jerry Gerber avatar
Brian, I'm shooting with the asi2600mm, it's not a full frame sensor.
Will the WR 3.0 allow me to use the whole frame without any vignetting?
I'd aactually prefer to get the lighter focuser.
Jerry
Here is a raw frame with only the autostretch applied if you want to double check for yourself.
https://www.amazon.com/photos/shared/cgUdG237Q66pyBjhUG9t6g.kB-0NDCR0AbfJIZwSsEpnl (46MB)
Your camera sensor is smaller than mine, so you should be good!
Jerry Gerber avatar
Thank you for posting those pictures.
I wonder why Ron at Moonlight says I should get the 3.5?
I'd rather spend less & keep weight down as long as framing doesn't suffer.
I am not sure on that. I can only speak from my personal experience.
Jerry Gerber avatar
Strange, Ron says that the 3.0 'might' clip the bottom edge of the light cone.
I'm not eeven sure what the 3.0 or 3.5 refers to. Is it the size of the opening?
Thanks
Jerry
Yes. The 3.0 has a 3 inch hole. The 3.5 has a 3.5 inch hole
Jerry Gerber avatar
Thanks again Brian for sharing your experience with me.
Carlos Tejeda avatar
Always had the curiosity of knowing if the Moonlite focuser is well center when rotates.
Carlos Tejeda:
It most definitely keeps the field properly centered. It’s a very well built unit. Probably over engineered but that’s a good thing in cases like this.
Upgrading from Quattro 200CF to 300P: seeking owner experiences and advice
I’m seriously considering upgrading from a Quattro 200CF to the Quattro 300P and would love to hear peoples’ opinions on the scope. I plan to get a CEM70 to run it. My image train is the ZWO ASI2600MM, ZWO 7×36 EFW, ZWO OAG-L, ZWO EAF. I already own ...
Discusses telescope upgrades and weight considerations for equipment changes.
Aug 28, 2025
Moonlight NightCrawler Focuser at Remote Site
I’m noticing the Moonlight Nightcrawler (WR3.5) focuser is taking between 3.5 and 4 minutes to focus. This is done remotely, my telescope is at a remote site. It’s been homed this afternoon. Is there a way to speed up this process? If it focuses 20 t...
Directly addresses Moonlight WR3.5 focuser performance and specifications.
Oct 21, 2025
