How to polar align your mount using the polar scope - a video tutorial
8 replies224 views
Piotr K. avatar
Hi guys, recently I made a tutorial on how to correctly polar align your mount using the polar scope. Reading across the internet I found out that there seems to be a lot of confusion about this method, despite it's really easy and fast to do. Here's the video:
Polar alignment using the polar scope - in 7 easy steps
I hope it will be helpful, and if you have any questions - feel free to ask!
Brian Puhl avatar
There is really no need to level an EQ mount.
Rick Krejci avatar
Brian Puhl:
You do if you are rotating your polar scope so that 0 is straight up.  Otherwise your "clock" position of polaris would be off.
Piotr K. avatar
Brian Puhl:
Can you please justify this statement? Please explain in your own words why do you think so
Kristof Vandebeek avatar
I would say that levelling your mount will make it easier to perform the polar alignment, but it isn’t necessary. The desired end result is that your mount is aligned to the north or south pole, and that can be achieved with a mount that is not leveled accurately.
How do you level your mount? By eyeballing how level it is, or by accurately measuring it? If there’s no real difference in both approaches, then how necessary is levelling?
Another question I have: by using this technique, how good is your polar alignment if you measure it? Does it work for long focal lengths?
Well written Insightful Respectful Engaging
Rick Krejci avatar
Kristof Vandebeek:
If you 3 point polar align, you are correct...leveling just makes adjusting easier since each axis will be independent.    For a polar scope, it's more important since you are placing Polaris on the "clock" and particular East/West leveling is necessary.
Personally, I just use my RAPAS on my Mach 2.   The mount has a bubble level and is on a pretty flat surface, so just a shim or 2 works.    I calibrated the polar scope with other methods (3PPA, PHD2) and confirmed several times it gets me within an arcminute, good enough for me.  If I need better, a minor tweak with 3PPA is easy, especially with the mount pretty level.
Helpful Insightful Respectful
Piotr K. avatar
Rick Krejci:
In fact, it doesn't matter which number is up. It can be any, 0, 3, 6 or 9. The important thing are the lines of the cross - they need to be aligned with physical vertical and horizontal directions, because only then positioning Polaris on the appropriate spot on the circle will point the RA axis towards the celestial pole.
Kristof Vandebeek:
Depends on how you polar align. If one uses the polar scope, then leveling will ensure that the vertical and horizontal lines on the cross are aligned with physical vertical and horizontal directions. If one uses other methods, like the procedures in ASIair or NINA (I think there is a PA procedure in NINA, right?), then levelling is not necessary, because one doesn't need physical vertical and horizontal directions as a reference.
Kristof Vandebeek:
I use bubble levels built in the heads of my EQ3-2, EQ5 and CEM25p mounts.
Kristof Vandebeek:
I never measured it, because I don't see any need to do it
Kristof Vandebeek:
What does the focal length to do with it..?
In fact, the only (important) issue caused by not very accurate PA is a slight drift in Dec axis, easily corrected by guiding. The periodic error (PE) in RA axis, at least in my mounts, is orders of magnitude bigger than this drift, so without guiding it wouldn't matter if I polar align precisely or not, because my subs would be ruined by PE, anyway   But I use guiding, and I routinely achieve 480 s subs on my EQ3-2 and CEM25p mounts, with imaging scales being 1,85"/px and  2,46"/px, respectively. Here's a log from one of my sessions on EQ3-2:
Rick Krejci:
EXACTLY!! In fact, only leveling in East/West matters, and levelling in North/South is not necessary, because (from the mount's point of view ;) ) it's equal to being located on higher / lower latitude. I'm really happy to see that there are still people around who understand this!! (maybe there is a lot of them, actually? But here in Poland the understanding of PA seems to be extremely low, especially since all these software-aided procedures entered the market... ).
BTW, what is "RAPAS"...?
Himanshu Pandey avatar
Thank you for that graphic.  I've been wanting to learn how to use the polar scope on my mount and that really helps clarify the procedure.
Well written Respectful
Rick Krejci avatar
Piotr K.:
RAPAS - Right Angle Polar Align Scope.   It's Astrophysic's excellent Polar align scope that you don't have to get on the ground to use since it has a right angle lit viewfinder.    Has a nice app to tell you exactly where to put Polaris.   As I said, can usually get within about 1 arcminute confirmed by Nina's 3PPA.
New to or Considering Astrophotography/astronomy?
I had posted this with a new image I’d uploaded as a change from the “typical” review of my processing steps/acquisition. A friend/commentor suggested I post in a forum, so this is the result. This is VERY subjective and based entirely on my experien...
Beginner astrophotography resource; polar alignment relevant to new practitioners.
Jul 31, 2025
CQ350 - Home Position
I recently got a Skywatcher CQ350 and have been setting it up for the first time. My previous mount was an Orion Skyview Pro GoTo, which I had to always manually set the home position. In setting up this mount, I got a little confused because there d...
Mount setup and alignment procedures directly related to polar scope alignment.
Aug 1, 2025
Fornax LighTrack II setup advice
Hello all, I bought a Fornax LighTrack II used for about 370€. It's just the tracking arm so that gave me room to improvise how I would like to have my rig set up and I've come to this final configuration. However, I am very open to any suggestions. ...
Tracking mount setup; polar alignment applicable to equatorial mount systems.
Jan 10, 2026
