Using two telescopes on the same mount: Piggy-back imaging
9 replies521 views
urban.astronomer avatar
For long, I have been using a small Takahashi scope (FS-60C) as a luxury guide scope for a larger 100mm refractor. The small Tak was mounted on top of the refractor and has served its purpose very well, providing pinpoint stars to the guide camera.
Recently, I decided to switch to an off-axis guider instead, connected directly to the filter wheel and thus handy for use also for other setups, i.e for my Celestron SCT scope. This seemed to be a neat and working solution, so I put the old Takahashi back away to collect dust. It felt a bit awkward to send the telescope into retirement, as the Tak is an excellent scope with flourite optics, and have only done the "dirty work" of guiding for the last few years, a job that any cheap refractor could have done.
So, I got the idea of perhaps using the Takahashi for piggy-back imaging instead of putting it back on he shelf? The scope was already fixed in position and everything related was in place, so it was simply just to connect an imaging camera with a filter where the guide cam used to be. The setup has the two scopes obviously poiniting in parallell, roughly at the same target. The Tak provides a wide field of view with a one-shot color camera, and the main, larger telescope collects narrowband data.
On the software side, I am using two instances of Sequence Generator Pro, where all equipment is controlled by the main "master" scope, as before. The second instance of SGPro, for the piggy-back imaging only has the imaging camera and the focuser connected. Thus, it becomes a "slave" of the master and has no influence on the control of the mount, guiding, etc.
This setup works up two the point when the master scope is about to dither, and ruins the sub frame of the slave telescope. Even with a small dither, the noise is clearly seen on the piggy-back image. It is not practically possible to sync the two imaging sessions such that they both can finish their subframes simultaneously, as there are differences in sub lengths and time of download. In addition comes guider settling time, focus adjustment at irregular intervals, etc. In this situation, it would have been handy to have a setting where the master instance somehow gets a signal to wait until the slave is in a state where dither is harmless.
I have an imaging example from this setup here, where it is clearly seen that the slave image is more noisy than it had to be:
Master image: https://www.astrobin.com/ad3068/?nc=user
Slave image: https://www.astrobin.com/d1ufwa/?nc=user
If anyone has a come up with a working solution for piggy-back imaging, I would love to hear from you.
-Martin
Sean van Drogen avatar
Synchronized dithering is what you are looking for, but I am not sure which piece of software could do that, think APT maybe. Someone else will come along with a better fuller answer.
Franz Eckhart avatar
The MGen 3 Standalone autoguider is capable of synchronizing the dithering of two scopes at same time. You would have to use an Aux Splitter, but it‘s possible!
Cs
Franzi Josef
Tim Hutchison avatar
I use Voyager to control my imaging sessions. While I don't use it, it does have an "array" version that does exactly what you want. It is made to control multiple imaging systems on a single mount.
I switched from SGP to Voyager about 1 year ago and I love it. There was some paradigm shifting for sure, but I find it to be much more capable. The author is very helpful if you have any support issues.
I think it would be worth a look.
Best.
Tim
Well written Concise Supportive
Christian Großmann avatar
Hi @urban.astronomer
I remember seeing a video from Cuiv the lazy geek on youtube.
https://www.youtube.com/watch?v=KDH6maXanJw
He uses Nina for his setups, but I am sure, you can find some useful information in it to set it up in SGP as well. I am quite sure that it could work. But I do not use SGP myself.
Maybe this helps...
Christian
David Redwine avatar
APT can synchronize the dithering of 2 scopes.
Taman avatar
I've just been looking for the same thing myself for a side by side system. Here's the link to the APT solution mentioned by David Redwine:-
https://astrophotography.app/usersguide/multi_camera_dithering___synchronizing.htm
Not tried doing it yet, but it looks promising.
Clear skies!
Tony.
Nikolaos Karamitsos avatar
I have four telescopes on one mount and i use apt. I can synchronise all four and dither
cs
nick
Linwood Ferguson avatar
NINA just added, in the 1.11 version, a synchronized dither plugin.  That's their "nightly" version and I do not think it has had a lot of testing yet, but it's available to try and I know the author is looking for feedback to actively improve it.
Gustav Lundby avatar
I'm just starting using a three scope rig. I'm using StellarMate - Kstars - Ekos - INDI. In Ekos, newest version one can use a "Pre Capture" script to fire other scopes cameras for each capture with the Main camera. In the script the exposure time can be set for each. It must be set equal or shorter than main camera. The other setting for the extra cameras, like storage path and ISO is best set in each cameras INDI device tab. This way one can do multi camera sessions without beeing hit by the dithering.
Excuse! My Pegasus Pocket Power Box Advanced is in for warranty. That's why you see all the dangling cables :-)
Sequence Generator Pro framing and mosaic and Astrobin - no longer working...
Anyone out there having issues with SGP framing and mosaic error when referencing an astrobin image. The error I get is There was a time when this, used to work Anyone having the same issue ?
SGP tutorial for GEM mounts may help troubleshoot framing and mosaic issues.
May 1, 2020
2 average scopes on 1 average mount?
Hey all, Does anyone here placed two scopes of medium weight on a mount that is not rated for very heavy capacity? For example 2 scopes by each is almost up to 10KG [with accessories] on a mount that is rated for about 20-25KG only
Directly addresses mounting two telescopes on same mount setup.
Jun 26, 2020
Ideas for handling different setups - how do you deal with your equipment
Hi all of you, over the last three or four years, since I began to do astro photography. I developed a method of handling my equipment. This works for me. But before I write some lines about it, I want to explain the reason for this thread. Astro pho...
Discusses managing multiple equipment setups, directly relevant to author's situation.
Aug 27, 2023
New travel setup based around Takahashi FS-60CB
With my main gear now sort of semi-fixed on rolling piers, the desire grew to have a true grab and go scope that I could take out to a dark site, the occasional star party, or on holiday. There are many options out there for small and very good scope...
Mentions Takahashi scope and managing different imaging setups for portability.
Jul 18, 2023
Auto guide setup for Orion ED80mm
Hello everyone, I have an Advanced VX that I’m using with an Orion ED80 and Celestron Stransense camera for quick alignment. I taking good pictures so far, however since my mount is old, I think I might be needing an auto guider. i looked at the Orio...
Discusses guide scope setup and piggyback configuration on same mount.
May 16, 2020
