[RCC] Caldwell 49 - Rosette Nebula
3 replies236 views
AmyWarble avatar
Reference image: https://app.astrobin.com/i/gj1z49
This is the first image where I used bias frames and increased the offset on my camera from 1 to 160.  The bias histogram was just off the left side of the histogram.  The result is that this image has substantially more detail and depth than my previous work, and less noise.  I'm not sure how much the bias frames contributes to that, but I think I understand now while my previous images had blotchy dark patches: I was clipping the dark pixels.
I think maybe the weakest part of this image are the stars, both color and brightness.  I worry I over-sharpened them.
What do you think?  What should I be doing to improve my images?
Well written Insightful Respectful Engaging
You're doing alright. Stars colors are a bit lacking and I'd have gone for a shade less reduction but given that you haven't got true colors to play with I think it's alright. But the FOV is a bit restrictive and I wouldn't have chosen the subject given that constraint.
Mel Martin avatar
I agree a wider FOV on this subject would have been helpful. But good processing and nice detail. Perhaps a bit more contrast. I think the stars look OK. They could be improved by removing them and adding the stars in their natural colors. That can be done with a separate unfiltered run at the target, or use the SETI Astro PI script that turns NB stars into RGB stars. I use that technique a lot and like it.
But this overall is a solid image.
AmyWarble avatar
@Mel Martin I will check out that script, thanks for the suggestion.
Well written Respectful
Player One Poseidon M camera showing clustered hot pixels in dark frames
Hello everybody, I recently bought a Player One Poseidon M camera (analogous to ZWO’s ASI2600-M Pro). The camera hasn't had its first light yet, because the weather has been bad and the filters haven’t arrived yet. However, I took bias and dark frame...
Discusses hot pixels in dark frames; relevant to noise reduction techniques.
Dec 14, 2025
[RCC]: M31
Good-day, My name is Brian and my journey into astrophotography began four years ago. I have spent a great deal of time studying Adam Block's videos along with other resources on image processing. It wasn't until recenlty I discovered Astrobi...
Uses bias frames and offset settings; demonstrates technical processing improvements.
Oct 29, 2023
Gradient in dark frames
Hi everyone! I recently bought the Player One Poseidon C Pro camera and after a very long period of cloudy nights it finally cleared and I got to try it. When taking the lights everything was normal. When the sun rose again the pictures got very satu...
Addresses dark frame issues with camera; directly relevant to bias frame discussion.
Mar 5, 2026
Which imaging acquisition and processing techniques could I learn more about to increase image quality and accuracy?
Hello, I use a full-frame mirrorless camera, I mostly do daylight photography, some night photography and astrophotography too. I did hightlight in bold keywords to make it easier to scroll thru, for those that don't want to read most of my post. Bef...
Seeks to improve image quality; author's goal matches this general inquiry.
Dec 29, 2025
Help - Vertical bands - Flats is the culprit - Can someone help me understand what's happening ?
Hi, Recently I am noticing some weird band like structures in my images. My setup - QHY600PH-M + Takahashi Epsilon 180ED + Astronomik Filters. I Captured RGB images in QHY 2CMS-1 Readout mode at 56 gain for broadband images. (mistake) After noticing ...
Troubleshoots image artifacts; relevant to understanding preprocessing and calibration frames.
Nov 23, 2025
