Square or circular?
14 replies529 views
Riccardo Civati avatar
Hi all
Is true that Moravian C3-61000 Pro needs Square 50x50 filters because with circular filters there Is vignetting?
Riccardo
It depends on configuration, camera + optical system ahead of camera.
TEC 140 ED with flattener 1x f/7.
Internal or external FW?
Either way, 50mm unmounted, round. You might get away with 2" mounted with the internal FW, by a very slim margin though. I wouldn't bank on it, however.
With your TEC140 you should be able to use 50mm round filters. If you were to upgrade to a different OTA in the future or to a larger sensor the square filters would be required. If you think that may be a possibility it could make sense to go to the 50mm square filters now.
Well Written Concise
Daniel Carter avatar
Riccardo Civati:
Hi all
Riccardo
I'm using the C3-61000 camera on a 12.5" iDK at f/6.8 and I have the 50mm round filters. They work fine with no vignetting. Like Bill mentioned, if you plan on going with a bigger sensor in the future, the 50x50mm filters would make sense.
Bob Lockwood avatar
I use 50x50mm on my C3-61000 because I already had them. If the price difference is not an issue, I'd just go with the 50x50mm.
Daniel Carter:
Riccardo Civati:
Hi all
Riccardo
***Hi Daniel
can you send me your master flat frames stretchd ( all filters)?***
riccardo
Riccardo Civati:
Daniel Carter:
Riccardo Civati:
Hi all
Riccardo
***Hi Daniel
riccardo
I'll get them to you via private messaging later today or tomorrow morning.
Valentine Treshchun avatar
Hi everyone! I wonder if anyone is using 50×50 square filters with Tak FSQ106 or similar scope with this camera, and is ready to share their flats? I’m using the 2” mounted Baader filters, and while I don’t see any issues with calibrated images, I’d love to compare other’s flats to see if it is worth upgrading to square ones.
My 1xLRGB flat frames bin 2×2 (for the sake of size) if anyone wants to take a look: gdrive link
Image train: fsq106edx4, native focuser & CAA, some m90-m68 adapter rings, MI OAG, MI 7×2” FW, MI C3 61k. Flats taken with PLL Giotto 150mm flat panel cover.
Thanks in advance.
Bob Lockwood avatar
This is a lum 2x2 flat using the C3-61000 Pro and 50x50 filters on an FSQ 106 with the 645 reducer, 381mm fl. No tilt has been applied.
2" mounted filters are too small for this chip,
With moravian c3-26000 and external filters wheel, Is It ok with 36 mm unmounted filters with apo f/7?
Is there vignetting?
@Bob Lockwood thank you for sharing your flat! It looks quite similar to mine, but I’m running native FL of 530mm on mine. Attaching L (screenshot of stretched flat) 📷 L_flat.jpg
L_flat.jpgOf course 2 years after purchasing the camera, I open the MI article on FWs: https://www.gxccd.com/art?id=759&cat=22&lang=409 and they do say that 2” will vignette, 50.4mm will be better, 50×50 are best. 50.4 unmounted offer 3mm extra clear filter aperture:
📷 image.pngimage.pngNow I’m considering whether to upgrade to 50×50 or at least 50.4 unmounted.
Slightly hesitant to moving to 50×50 as this requires a new FW (7×2” and 7×50mm square FWs are different in size), and resell demand for MI external non-standalone FWs is probably 0.
Still looking forward to seeing some example flats from FSQ106 & 50.4 unmounted filters to see if the upgrade is worth it.
@Riccardo Civati according to the above, 36 unmounted should work fine with C3-26k & EFW.
Let me pop this topic up again.
Still looking for some FLATS from FSQ-106 on native FL, 36×24 sensor, and 50×50 square and/or 50.4 unmounted filters.
Still on the fence on whether to upgrade from 2” to square, as I appear to be able to remove almost all artifacts with flats and post-processing, over time, but.. but.. 🤔
Moravian C3 camera
Hi! I want to buy a C3-26000 PRO CMOS, but I already have the ZWO filter wheel and OAG-L. Is it possible to bolt the ZWO EFW to the camera? If not, which adapter do you recommend? Cs
Discusses Moravian C3 camera compatibility with filter wheels and accessories.
Jan 9, 2026
