Keith Belzner avatar
I have installed the plugin Touch-n-stars on NINA and have been going through the interface to see if I like it. Acouple of items I'd be interested in having on it.
1. I noticed missing from the camera tab and settings is no mention of dithering.
2. The ability to see the image if I start the sequence from a different computer, IE started it on my desktop pc but I want to monitor the progress on my phone.
3. The settings, exposure time / gain ect, dont match what is on my other devices at the same time.
Has anyone used it, and how do you like it so far?
Rick Krejci avatar
I use it for things like 3 point polar align and connecting/disconnecting equipment.  For your #2, I routinely start sequenced on my laptop remoted in to my Mele mini PC and then later check and zoom into the image on TouchNStars without an issue.    I never start sequences on TNS or set up dithering.
I did notice, for an individual exposure initiated from TNS, the gain/offsets don't match the settings in the main NINA setup.
Rick
AcoVanConis avatar
Keith Belzner:
I'm on of the devs, glad you like it so far.
1. Dithering is is visible in the sequence and with our upcomming update you are able to edit all parameters. If you have additional ideas on how to improve it feel free to create an issue on our github page: https://github.com/Touch-N-Stars/Touch-N-Stars/issues
2. This is a known issue and we are working on further synchronization between diffrent devices.
3. Please provide an example as a github issue, so we can take a look into it.
Regards
Aco
Concise
EQstar double motor system won't connect to iPhone with SynScan pro
So I own an EQstar double motor system. When I first installed it I owned Samsung phone and tablet, and I got everything to work as it should have. Now after having been ignored in the storage shed for several years, I now own an iphone, and I cannot...
Remote monitoring capability across devices similar to author's phone monitoring request.
Nov 17, 2025
ASAIR Plus - Mini PC
GDay all. I was pulled into astro when watching youtube three years ago. The ASIAIR Plus made it pretty simple for this non guru and besides I had no laptop. I run an ethernet cable to the Air an monitor via IP address on my desktop PC. I have no dra...
Mini PC solution for remote astrophotography sequencing and monitoring needs.
Dec 8, 2025
