What's the best source out there for spacers, adapters for various thread configurations, shims and such.
Thanks I'll look those over. I want to put together a kit of basic parts so when I have an idea I can just rummage in the bin and put together what I need instead of waiting a week for a part delivery.
John Hayes:
Precise Parts
for standard pieces, like a set of say M54 extension tubes, aliexpress is by far the most economic solution often running at ~15 euro a piece when a similar tube often costs 40+ euro at other sources. Their search engine is pretty "peculiar" at best, so finding what you are looking for is often a bit cumbersome.
Be careful with cheap adapters! I discovered that some of the cheaper adapters and extensions have the threads cut in a way result in the tube edges are not perfectly parallel with each other, which can result in tilt. I have two 33mm length, 48mm diameter extension tubes: one from Stellarvue and one cheap one. The cheap one produces tilt while the Stellarvue one does not
