Support requests are handled via the support form so they can be tracked and resolved properly. This section is for community discussions about the AstroBin platform.
Jim Thommes avatar
I find the Sky View window on an image to be very useful. I see that RA is sometimes in hrs/min, and sometimes in degrees.
Is there a setting that I can set in order to have Sky View show RA in Hrs/min?
Jim -
Salvatore Iovene avatar
Hi Jim,
I'm not sure I follow. Nothing on AstroBin is labelled "Sky view". Can you send a screenshot please?
Jim Thommes avatar
Here is what I see on my images:
Here is what I would like to see:
Hi Jim,
that's part of AstroBin's advanced plate-solving powered by PixInsight. You can learn more about plate-solving on AstroBin here:
https://welcome.astrobin.com/features/astrometry-tools
It's part of the AstroBin Ultimate subscription plan. You can compare the plans here:
https://welcome.astrobin.com/compare-plans
And see prices here:
https://welcome.astrobin.com/pricing
If you want, you can upgrade here:
https://app.astrobin.com/subscriptions/ultimate
If you do upgrade, you won't pay anything immediately, but only be charged with the difference at the end of the current billing period.
Hope this helps!
Salvatore
Jim Thommes avatar
Salvatore,
Thanks for the explanation and subscription options.
I may upgrade at some point; for now I will divide RA in degrees by 15  (in my head by approximation)  to get approximate  RA in decimal hrs.
I am just looking for a rough sky location for an interesting image I view. I see now that the sky map shown will depend on that user's subscription level.
Jim -
Another useful ChatGPT use: Compute RA and DEC offset for a comet image
With the short window we have for Comet C/2025 A6 Lemmon right now, I don’t have time to fiddle with trying to frame the comet in such a way that the comet nucleus is on the corner and the tail runs diagonally across the frame so I can get as much co...
Discusses RA/DEC coordinate systems relevant to Sky View display settings.
Nov 9, 2025
Sky Safari 8 pro - Selection FOV with Double Tap to Rotate
I like to use Sky Safari to show different FOVs on an object and choose how I’d like to shoot it. Sky Safari has a “Double Tap to Rotate” feature. Simple double tap the screen and you can rotate the view without having to go in and out of the setting...
Sky Safari software interface settings potentially similar to Sky View configuration.
22 days ago
