Noise on sensor when cooled to max
6 replies168 views
Niels_L avatar
The outside temperature is currently 29.9C (yes, I am in summer) and I am cooling the camera to -10C as I normally do.  I've seen this noise a few times in the centre of the sensor but never paid much attention to it as it disappeared (guess the outside temperature dropped).  I did now notice it comes up when the sensor goes below around 1C and gets worse the lower the cooling goes. I guess I am getting to the max of the cooling? I take it this is then noise from the cooling electronics?
With temperatures changing throughout the night, it would be impossible to take flats at each temperature. At these high temperatures, should I then increase the sensor temperature to 5C?
Quick side temperature, do darks need to be taken at a specific sensor temperature?
Below is an example of one of the flats at -6C with a STF. First is full flat image, second zoomed in somewhat, third on pixel scale.
Full image:
Zoomed in:
Pixel scale zoom:
Francesco Meschia avatar
That’s not noise, IMO. It’s ice crystals. Try cooling a bit more slowly. If it doesn’t help, you may need to think about replacing the desiccant tablets in the sensor chamber.
Well Written Concise
Arun H avatar
Ice crystals, not noise. It will usually go away with time, or you can cool it above freezing.
Ditto what Arun H said about cooling temperature. I cool my 294MM at 0C, the difference compared to -10C is minimal and I don’t need to worry about ice.
Josh avatar
There's no need to cool so deeply. the 2600, only has a delta-T of 35c. You're cooling power would be maxed out, and tha'ts a good way to unnecessarily stress the electronics.
The idea behind sensor cooling is to get a stable temperature, not the absolute lowest. Your darks should be taken at the same settings as the lights frames you're matching them to - Exposure time
Gain
Offset
Binning
Temperature.
I can comfortably image at 0c all year round. my winter lows are around 5c.
Niels_L avatar
Arun H:
Ice crystals
Interesting!  Indeed, it seems to apprear around the 0C.  I decided to run tonight at 5C as 0C is on the edge for the ice...
Arun H avatar
Arun H:
Ice crystals
during summer, I took to cooling to 1 C for that reason and the problem went away. Pretty sure cooling to 5C will work for you. Let us know how it turns out.
One dew solution that may not be for everyone.
I live in coastal Southern California and I have always struggled with dew prevention on my 10” DIY newt… I’ve tried dewshields, dew heaters, burning sage, shamans, you name it. Dewshields are ungainly and huge. Dew heaters would generally overheat t...
Discusses thermal management issues relevant to sensor cooling problems.
Nov 28, 2025
ASI533MC Pro Cooling Fluctuation!
Hello, Coming from DSLR, I Just got an ASI533MC Pro and trying it for the first time. I'm connecting it to ASIAIR Plus (Both power and USB 3). I set the cooling to -10 C and took the light frames with no issues. When I'm taking Flats and Dark...
Relevant - noise issues with sensor cooling to -10C.
Mar 6, 2023
