Sky-Watcher CQ350 pier adapter and power connection
3 replies157 views
Mauricio Christiano de Souza avatar
Hello all!
I will soon be installing a CQ350 mount on my observatory pier, but I couldn't find a reliable source of information or technical drawing of the base of the mount head, where I would fit my personalized adapter for my pier. It looks like it uses the same fit that the EQ8 uses, but I wanted to be sure before expending money on anything. The manual of the CQ350 doesn't have a technical drawing of the base plate, however the EQ8 manual does, so if they really use the same base plate design, I could work from that.
I would also like to know if it uses the central M12 bolt from below or just the the two M8 bolts on top to hold it in place.
Below is an image I found for the EQ8. I would like to know if these measurements will work for the CQ350.
And here is what I found in the EQ8 manual:
Another information that I wanted is the exact name of the power connection of this mount. Is it the same from the EQ6-R Pro?
Many thanks in advance!
Michael Gorman avatar
It is the same as the EQ8. I personally have an order in with Dan's Pier Plates for an EQ8 adapter. I used his pier top plate and anchor kit, for a HEQ5 when I poured my pier last year, so now i can just swap the top adapter plate and call it a day.
The power connector is a GX12-2. https://www.amazon.com/dp/B0D2V5WTTP?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
I bought that so I can lop off one end and wire it to my 12V system in my observatory.
Deepan Vishal avatar
It’s pier connection is same as EQ8. Check out my gallery for CQ350 mounted on a Pier Tripod that’s used with EQ8.
It’s power source is same as EQ6-R.
Michael Gorman:
Deepan Vishal:
Many thanks to you both!
Mount skywatcher CQ350 PRO
Being interested in purchasing the mount, I would like to know from those who use it their opinions, problems and above all how to guide with phd2. Thanks for the replies.
Mount installation and power connection information relevant to purchase decision.
Apr 4, 2023
Ioptron Tri-Pier with Strain Wave Mounts
Possible Tri-Pier Solution for Strain Wave Mounts. -I had a problem with the Tri-Pier flexing under unbalanced loads previously discussed with some other members here. It turned out to be the top plate moving in the pier. It was flexing up a noticeab...
Relevant pier installation and mounting hardware discussion for similar equipment.
Sep 27, 2023
Discusses EQ8 mount construction details relevant to CQ350 compatibility research.
27 days ago
Building a pier (connection between EQ6-R Pro and pier)
My summer project among other things, will be building a pier. I can see there are different connectors that can be used between the pier and an EQ6-R Pro (my mount). So wanted to hear what peoples experience was and if there is anything to avoid or ...
Discusses pier adapter and power connection for observatory mount installation.
Mar 25, 2023
Sky Watcher CQ350 backlash issues
Just bought a new S.W. CQ350 mount and the Dec backlash is 0.5mm at the end of the saddle! Does anyone know how to adjust the Dec backlash on these mounts. Thanks
CQ350 mount technical information and setup guidance directly relevant.
May 19, 2023
