Strange things in my lights
6 replies246 views
Adrimt33 avatar
Hi everyone
I am new to the astrophotography world.
The other day while i was capturing my light frames i noticed some strange spots. I don´t know if it is dust or if something is wrong with my set up.
I would appreciate any advise about what it is and if i can remove it
Thank u all in advance
Richard Mak avatar
That's dust on your sensor or sensor window.
As mentioned above it's dust motes. You need to take flats in order to remove them (and correct for many other things besides). Depending on what you are going to use for processing the raw images there will be the right procedure to follow for light frame calibration. Just google it up or ask here for more details.
Beat Wirthmueller avatar
Hi welcome to this hobby - hope you will have a great time!
Yes it is certainly dust - it is always a good idea to keep the camera sensor or the screen on it as clean as possibly - same as with daytime photography. Next step is taking flats, bias frames and dark frames and so on. When I started with astrophotography  I skipped all these additional procedures until I noticed how important they are for the final image.
Adrimt33 avatar
Thank u all for your advice
I will try to clean my sensor with the proper tools and the calibration frames.
Dunk avatar
One more tip: after cleaning, if you can keep your imaging train assembled it should prevent this happening again. Not always possible I know, but thought I'd mention.
CS.
Rick Krejci avatar
If your camera's still attached to your telescope and you haven't moved it, you can still take flats if you want to try to salvage.   Easiest is to point to the sky at dusk/dawn (away from lights and/or the moon) and take some short exposures so that the image histogram if about 50% (the image looks medium gray unstretched).    If you want to do this, do it before cleaning the sensor so it records the dust.    I also take a bunch of bias frames (shortest exposure frames with the telescope covered at a similar temp as you took the shot with).    With just bias and flats, you should get rid of most of the issues.    I generally don't take darks or dark flats since the thermal signal on the ASI2600 is insignificant even for 300 sec exposures.
Strange persistent structure/artifact in old (2025) subs — what could it be?
Hi everyone, Quick (and kind of funny) question. I revisited some March 2025 data of the Dolphin Head Nebula—only 13 × 180s frames. A few days ago I resumed the project and decided to register/align those 2025 subs to my new 2026 data so I could comp...
Jan 24, 2026
ZWO ASI 2600MC producing doughnut artifact in center of images
Hello everyone, I have had a ZWO ASI 2600MC for about a year now, and I have noticed that all the images I have taken with it since then have a strange artifact in them. Basically, it looks like a doughnut in the center of the image. This is particul...
Nov 27, 2025
Gradient in dark frames
Hi everyone! I recently bought the Player One Poseidon C Pro camera and after a very long period of cloudy nights it finally cleared and I got to try it. When taking the lights everything was normal. When the sun rose again the pictures got very satu...
Mar 5, 2026
extreme offset vignetting in flats and lights
This issue has persisted for a while now through at least 3 set ups and I honestly cannot for the life of me figure out what is causing this. Here is an image of one of my flats which displays the extreme offset in vignetting in my imaging train whic...
Nov 9, 2025
Problems generating my flats
Hi! Does anyone know why my flats shots have two circles in the center of the image? My equipment is a WO RedCat v3, and in the optical train I have a ZWO filter drawer, a filter wheel, and my ASI 294mm Pro camera. I have the filter drawer because I ...
Aug 5, 2025
