Problem with my QHY 533 color sensor?
15 replies417 views
Hassaan Zaheer avatar
I am using a QHY 533 color cooled camera,
i am seeing some weird banding around the edges.
Can some one identify the source of the issue.
I am using flats, darks and bias frames to calibrate the data.
The flats are working because all the dust motes present during imaging are removed.
You can see the banding on the bottom right and top left seems to be the worst. though the original banding shifts after meridian flip .
I really don't see anything unusual there. It really looks like the usual stacking artifacts that you get when there is some drift between the frames. If you use NINA you can minimize that by invoking the "re-center on drift command" found in the advanced sequencer. I use that command to limit total drift to no more than 0.25 arc/min. but you can set any value that you like.
I am talking about this artifact specifically.
I am doing a recentering after drift, this image is cropped before applying DBE.
Does a single frame show it once it has been calibrated?
TiffsAndAstro avatar
Nothing odd I can see.
Again, I see nothing unusual. It's a very dusty area so there's a lot of variation. You are going to see all sorts of ugly things when you stretch an image that much. How does your final image look?
Well Written Insightful Respectful Concise Engaging Supportive
after severe editing i can make it work.
ill post another image that highlights the problem much better.
Here you can see a pattern that shows around the border of the image.
Markice Stephenson avatar
Hassaan Zaheer:
I had something weird like this happen when I started using my sharpstar Newtonian. Never occurred when using the same sensor/filter along with the RASA. After having done a channel extraction to troubleshoot further, it seemed to only impact the B channel. I've switched filters which yielded better results (Antlia L -> Optolong L), but didn't completely eliminate the problem. I also tried using 100 gain instead of 0 gain, which also didn't completely eliminate the problem but it did a better job at burying it. It doesn't happen with my narrowband filters, so maybe it's a stray light/reflection issue. Or an issue with the flat light source. Haven't been able to figure it out
Hassaan Zaheer:
*This has nothing to do with the sensor/camera. It has a lot to do with calibration/post-processing. Again, does it show on a single frame?
Hassaan Zaheer:
was the moon about, beaming it's light polluting goodness in?
This looks surprisingly similar to what I got on M42 in dnb last night ;)
Hassaan Zaheer:
No it doesn't show up on a single frame.
Only when calibrated and stretched.
TiffsAndAstro:
Hassaan Zaheer:
I have taken shots during full moon and no moon and the result is the same.
it disappears when i use a duo narrowband filter.
Hassaan Zaheer:
So there you go, it's the processing not the sensor.
Kristof Vandebeek avatar
What telescope and other accessories are you using?
Al Lazuli avatar
i would suspect the issue here is that you are running gradient correction before cropping the stacking artifacts. crop about 10-20 pixels off each axis before running your gradient correction and this will likely disappear. try it and see
Kyle Cerniglia avatar
Al Lazuli:
This is it right here, the telltale sign is the very bright strip on the bottom edge of the image.
When you do background extraction, manually plot the points, don't use the auto-plotter, as it will get way too close to the edges, or get placed on stars.
Help - Vertical bands - Flats is the culprit - Can someone help me understand what's happening ?
Hi, Recently I am noticing some weird band like structures in my images. My setup - QHY600PH-M + Takahashi Epsilon 180ED + Astronomik Filters. I Captured RGB images in QHY 2CMS-1 Readout mode at 56 gain for broadband images. (mistake) After noticing ...
Similar banding issue with QHY camera; vertical bands related to flat calibration.
Nov 23, 2025
Rotation shift after meridian flip (no electronic rotator)
Hello, I recently noticed that during my last two sessions of shooting that I experienced a shift in the field rotation after the meridian flip. All images taken before the meridian flip are same orientation and matches with framing assistant, and al...
Meridian flip causes field rotation shift; author mentions banding shifts after flip.
Oct 28, 2025
Dark bands at top and bottom of Minicam8M
EDIT: QHY support responded with the following statement: “We can basically confirm that this phenomenon stems from the light-gathering limitations of the Minicam8M sensor structure at extremely fast focal ratios (F4), rather than from mechanical obs...
Dark bands at image edges on QHY camera; directly comparable hardware issue.
Nov 8, 2025
