Rokinon (Nikon version) to M48 or M42 connector?
8 replies78 views
Rob Calfee avatar
Hi all,
I have the Rokinon 135mm, Nikon version. Can someone point me to the correct connector to connect to a ZWO astro cam, M48 or M42? I’m setting up a wide field rig and assumed I had the correct connector. Assumptions suck most of the time.
Thanks,
Rob
Well written
That depends on the camera, not the lens. But I'll assume is like mine and both would work but the internal flange is usually M42. You'll need the right spacing, 46.5 mm from sensor to lens flange.
Rob Calfee avatar
Here’s a couple of photos of the connector.
dkamen avatar
Shouldn't the connector go to the back of the lens?
Rob Calfee avatar
That is the back of the lens.
You need a reverse flange adptor for Nikon lens. ZWO sell them with the right spacing (and possibility of having a drop-in filter) or you can buy a commercial one (they usually take up 9.5-10mm of back-focus) and then add the required spacing rings, if needed. I have one variable adaptor from Geoptik that does both Nikon and Canon and anything in between with inner 1.25" thread for filters.
Rob Calfee avatar
Indeed that's the one.
Rob Calfee avatar
Questions about autofocus with the Rokinon/Samyang 135mm f/2.0 ED UMC
I am looking to expand my travel rig and add this lens for a wider field of capture. In particular I would pair it with my QHY 268MC, C-sized camera. I have noticed a couple of mounting setups, each of which include mounts and connections that pair w...
Rokinon 135mm lens paired with astro camera; discusses connector compatibility issues.
Aug 7, 2023
ZWO EAF and Esprit120ED issues
Hi guys, Was just looking for some advice if possible please. I recently purchased the esprit 120ed. I have connected up my eaf to the esprit 120ed with the correct mount required etc and on the left side (opposite to the fine tune side) After connec...
ZWO equipment setup; may address connector and integration questions for ZWO cameras.
Jun 28, 2023
