How to use ZWO ASI 385MC
Avillamario
58 replies718 views
Avilla avatar
Hello! I am new to astrophotography and I need a little help getting started. For some reason, when I attach my ZWO ASI 385 to my telescope (I have an Askar 103 APO), I can't see the sky. If I get an object centered in my telescope, (such as the moon) it appears as a very small dot, or as though I'm looking through a tiny hole at the end of my telescope tube. I've tried focusing it, using extenders, adjusting my settings, etc, etc. I think it's the way I put it into the telescope, but I'm doing it exactly as directed. Does anyone else have this problem?
mario avatar
avez vous tester de jour pour faire une mise au point sur quelque chose comme une montagne,  une colline, bâtiments, églises, etc..
Avilla avatar
mario:
Hello! Yes, we tried that. It's as though the camera just shows a small dot of light/whatever the telescope is pointed at. We could see the moon through it, but it was extremely small with a black area (inside of telescope tube?) that wasn't the night sky around it.
mario avatar
Avilla:
votre camera est vendue avec un objectif qu'il faut retirer pour l'utilisation sur le télescope.  il se dévisse  et vous installez l'adaptateur  au format 1"25 sur la camera .
avez vous fait celà?
Avilla avatar
mario:
Avilla:
Yes, but for some reason, it works better with out it. With it on, I believe the screen was black or it showed only the small dot of light.
mario avatar
Avilla:
*** Ecrivez votre réponse ici *et lorsque vous utilisez la camera avec son objectif (camera tenue dans vos mains non montée sur le télescope )**
en faisant la mise au point voyez vous le paysage ou maison ou autre avec?
je précise bien sans l'installer dans le télescope
Avilla avatar
mario:
Avilla:
*** Sorry- When not attached to the telescope and without the telescope adapter, I can see clearly and full-screen. However, with the adapter on, I see a white screen and it changes to dark if I hover my hand over it. ***
mario avatar
Avilla:
donc la camera n'a pas de probleme si vous voyez bien ce qu"il y a autour de vous lorsqu'elle est équipée de son objectif c'est juste une histoire de mise au point à mon avis.
quel télescope avez vous?
pour les réglages quel logiciel utilisez vous:  asi studio ou sharpcap ou autres?
êtes vous en mode vidéo et le gain sur 100 environ ?
Avilla avatar
mario:
Avilla:
*** I have an Askar 103 apo. Also, we tried it with an extender and the 1'25 adapter on, (doesn't fit but we managed) and we got a clear image. Should I need an extender? I use ASI Studio and even with the gain on 100 I can see nothing no matter how much i focus. ***
mario avatar
le format de l'image dans Asi Studio est bien 1920x1080  ?
pour ce qui est de réglages contraste, gamma, saturation et autres, tout en bas vous avez "par défaut"
avez fait un essai en reculant la camera à la main du tube optique et voir si vous pouvez obtenir la mise au point?
avez vous une barlow pour augmenter la focale?
Avilla avatar
Here it is with the barlow lens on. Is this normal? I have the settings on default and changed the resolution as you said
Oscar H. avatar
the amount of reduction in focal length it takes to turn the moon into a dot is impossible to have with your native focal length and your camera
Oscar H. avatar
Avilla:
I think that's a planet
Oscar H. avatar
let me see if I can find out what planet, hold on
Avilla avatar
Oscar H.:
maybe can you show us a diagram of your image train, or a picture of it? the way you used it when you say you saw the moon as a dot; I think that would clear up everything in a flash
you say you "see", can you explain what you mean by that, what are you seeing through?
*** Sorry for the confusion, I'm not sure if you can see the photo I just sent, but the moon was in the 'little hole' as a small, unfocused dot.  ***
Avilla avatar
Oscar H.:
Avilla:
*** Looks like it, but that's what shows when I put on the barlow lens and point it at anything. ***
Oscar H. avatar
Avilla:
Oscar H.:
Avilla:
could you take a picture of your image train?
mario avatar
²cette image n'est pas d'aujourd'hui! car la lune n'est pas pleine actuellement c'est le premier quartier
Oscar H. avatar
mario:
I think it's not the moon; the amount of focal length reduction required is impossible to have with the OP's native focal length; no reducer or field flattener or barlow would do that
mario avatar
tout à fait d'accord avec vous ce que l'on voit sur l'image n'est pas la lune (pleine) avec une lunette de 130mm et camera au foyer  au format 1920x1080
Avilla avatar
Oscar H.:
Avilla:
Oscar H.:
Avilla:
*** I'm completely new to this so I hope this is what you mean. Had to make it small because of size limit ***
mario avatar
de quelle pays, région êtes vous avez vous un club d'astronomie prêt de chez vous ?
Avilla avatar
Oscar H.:
mario:
*** Correct. The 'moon' you are seeing is the view I get when I attach my camera to my barlow and telescope. That's not the sky, or the moon. I'm confused as to why it is showing only a small dot of light***
Avilla avatar
Oscar H.:
mario:
mario:
*** I'm in the US, and I don't think I have an astronomy club anywhere near me***
Can we see what is attached to the camera, if anything. I mean, just the camera not the barlow or the scope, just the camera and whatever else is screwed onto it?
Serious Stray Light Issue - William Optics UltraCat 56
I’m posting this to see if anyone else has experienced or can verify this problem in their UC 56 telescope. I received the telescope February 2, 2026 from Agena Astro. The quality control certificate that was enclosed was dated December 5, 2025. The ...
Different telescope model; stray light issue may relate to optical path problems.
Mar 1, 2026
Telescope Mirror Cleaning
Just sharing my success with what is probably a 'cheats' way of cleaning my 8" GSO Classical Cassegrain primary & secondary mirrors. The larger size of the 8" telescope tube allowed me to get away with it. Instead of the recomme...
Mirror cleaning could affect image quality; worth checking before troubleshooting further.
Aug 10, 2025
ZWO ASI 2600MC producing doughnut artifact in center of images
Hello everyone, I have had a ZWO ASI 2600MC for about a year now, and I have noticed that all the images I have taken with it since then have a strange artifact in them. Basically, it looks like a doughnut in the center of the image. This is particul...
Same camera brand; optical artifacts could indicate similar attachment or optical issues.
Nov 27, 2025
“Lens not attached” Nikon + RedCat 51
Hello all, After finally getting off my but and buying some better equipment I am finally moving closer to targets. for the first time I finally set up all my new gear last night. WO Redcat 51 Nikon d5100 Star Adventurer 2i pro Ioptron SS tripod And ...
Author cannot adjust camera settings when attaching scope; similar attachment problem.
Feb 19, 2023
How to know if OAG-L prism needs to be adjusted?
Hi, I have recently set up my ZWO camera, guide camera, filter wheel and OAG-L as adviced on ZWO webpage to achieve the 55 mm backfocus needed. I have read that the prism needs to be ajusted (up and down, see attached image for ilustration purpose Pr...
ZWO camera setup guide; relevant to ZWO camera and equipment configuration.
Feb 22, 2023
