Streak on Flat
2 replies82 views
Jerry Gerber avatar
Anybody know what this streak on a flat might be caused from?  I just noticed it for the first time this morning, my scope is in a permanent location and the sensor and filters haven't been removed.   Could it be dew or a scratch?  The scratch hypothesis is unlikely as I would have noticed it before.
Thanks,
Jerry
Is it calibrating out?
Jerry Gerber avatar
Don't know yet.  I am running WBPP right now and will know in a few hours.  It might be a water streak on the sensor cover, or a filter.
Dark vertical streaks in stacked image
I've been struggling with trying to understand the source of these streaks I see in some recent stacked images. I'm hoping someone here can offer an idea as to what the source is. I'm hoping it's not the camera itself. My set up is a ...
Streaks in stacked images may relate to flat field calibration issues.
Aug 21, 2025
Green banding issue in WBPP when using flats
Does anyone know what might be causing this green banding? I’ve never encountered this issue before, and it disappears when I exclude flats from WBPP. I have inspected my flats, and they seem normal. I’ve yet to try retaking the flats or do more test...
Green banding with flats suggests flat-related artifacts causing visible defects.
Feb 7, 2026
Problem with Flat Frames
Hi all, I haven't really been happy with an image I took of LBN 1093 back in May. I did do an initial edit which turned out ok, but I would like to re-edit this data with new techniques I have learnt over the past couple of months. Whenever I try...
Author investigating flat frame defects; relates to calibration frame problems.
Jul 21, 2023
