This round I had just above 5s exposures and the dew shield, the difference in the single exposures are quite big. The new one is to the right.
I'll post an update after stacking everything.
Paul Larkin:
Maybe you already have the controler but for those of us who don't, getting it right manually, at least for me, has proven to be less effective than a dew strap. It may also help reduce ice formation inside the tube. Maybe the ring set low, with a strap around the shield might serve as well.
Everything mentioned in this thread was done by me. Replaced focusers, replaced filter wheels, on and on, everything.
Over a period of several months worked with people at pixinsight and other forums. All the above was addressed.
Finally, and got confirmation by Roland Christian, that it is reflections. So unless you can resolve this, forget the rest. All of what is being said here has been said countless times before.
The celestrons with reducers are at best APC sized. Otherwise reflections kill the image.
Moving it or removing it will do nothing.
Been there done that.
On astronomy tools there is a tool that you can use to determine the distance from the sensor that dust mites and reflections show up. Maybe that can help?
I did this and found the reducer was where all the reflections were coming from.
So for me, I have decided to do only narrow band. No issues there.
I'm going out on a limb here - Do you have the reducer specific to the EDGE and not the non-EDGE models? Not sure whether that would be an issue or not.
I've had my reducer/OAG/EFW setup for 7 years with no issues. This is quite baffling! Hope a solution can be found.
Yep - that's the one designed for EDGE SCTs and the one I have.
You're got a challenging problem on your hands and I hope you are able to solve it with your own testing and ideas from the Astrobin community.
If I think of anything else, I'll let you know. Best of Luck!
If there's any comparison testing that would help Jan, let me know.
I realise that I never updated this thread so I thought I’d post the conclusion so that people who end up here through searching can see it.
I got some advice from user AwesomeAstro in my DM’s who had been through these exact issues as well. After thorough testing I ditched the reducer and the reflections went away.
- A year or two prior to this I had tested the telescope with my ASI533MM (LRGB) where I didn’t have any issue with calibration - thus the reducer seems to work well with small sensors.
- When paired with ASI2600 cameras I got these uncorrectable reflections that went away when I removed the reducer. Thus I concluded that the reducer is faulty, which Celestron somewhat confirmed via e-mail without actually offering to do anything about it unfortunately.
After I brought everything inside I noticed a few months later that some of the glass elements in the reducer had come loose. This might be due to temperature changes as I didn’t notice anything at first. I have not done any testing with it since as I got tired of wasting clear nights, also I found the setup to work very well without the reducer.
TLDR; The reducer was the source of the reflections - I stopped using it and everything has been fine.
