Guiding experience
1 reply281 views
Stuart Anderton avatar
How have folks found guiding with this mount?
jmdl101 avatar
Stuart Anderton:
Mine is pretty good, around 0.8 average. I also only have a small 400mm refractor on it and guide through a oag. Other users have had better guiding with it. For me, it's perfect for my Askar fra400, I can take as long of exposures as I want with no issue. I pretty much use 300s for just about everything, sometimes 600s for narrowband or duo narrowband filters.
​​I will say, the Juwei-17 is only a little bit bigger and heavier than the J14, and only a couple hundred dollars more, and comes with a dual saddle. In my opinion, the J14 isn't really worth the trade off to only save $200 or so. I got my J14 after having my J17 for a while, mainly just to try it out, if I could do it over again I would get  a second J17 instead.
Cooling fan usage during imaging on RC telescopes: vibration concerns
I’m looking for real-world experience with running cooling fans during imaging on RC telescopes. I have a 12″ Ritchey–Chrétien (TPO/OPT, GSO-made) with the standard three rear-cell fans. Running the fans clearly helps to reduce dew issues over the co...
RC telescope mount performance relevant to guiding experience inquiry.
Jan 27, 2026
Paramount MYT + Nina + PHD2 guiding issues
Hey folks, quick question for anyone running a Paramount MYT with NINA and PHD2. My Paramount is doing my head in. Everything is set up correctly as far as I can tell, SkyX, ASCOM, all that. But every now and then PHD2 throws up the error “your mount...
Direct match - guiding issues with specific mount and software.
Nov 27, 2025
Experience with Juwei-14 from Aliexpress
Hi all! the reason behind this post is to make avaliable some real world experience with the Juwei-14 mount, as there is so little info online, so i hope its usefull for few of you looking for an alternative to more expensive mounts. So, i got my Juw...
Real-world mount experience sharing aligns with author's request.
Oct 15, 2025
Biggest Newt You've Run on a Mach 2?
I'm toying with the idea of getting an imaging newt in 2026 or later and wondering how big some of you have gone for a Mach 2. I've been chatting with Catalin from CFF and he makes a 250mm and a 300mm f3 Newt. The 250 I think would be no prob...
Mount capability discussion relevant to guiding performance considerations.
Aug 10, 2025
