Jerry Gerber avatar
The other night I was imaging  remotely and when I awoke in the morning to inspect the subs, many subs were totally out of focus.  The seeing wasn't good that night, but not that bad!   I  thought I may have a problem with the Sesto Senso 2 focuser.
Tonight the same thing happened, only the seeing is good.  When the filter wheel changed to the green filter, all of the green subs were out of focus, whereas the Luminance and Red subs are fine.  I manually changed the filter wheel to the green filter (even though it was supposedly already there) and suddenly I could achieve focus both manually and automatically.
When I installed the 7 filters at home I was very careful to make sure they were snugly screwed into their respective slots.   I am now almost sure there's some kind of issue with the filter wheel, but not sure if it's an installation issue or a defect in the filter wheel itself.
Anyone have any experience like this?
Thanks,
Jerry
Well written Engaging
adrian-HG avatar
thats happen to me because the filters  i use are from different brands and  they are not parfocal , every filter have a different focus point
Is this a sudden change? Is it working ok if you do an autofocus after each filter change?
Jerry Gerber avatar
I use the same filter brand for all 7 filters.  The problem might be resolved (I'll know tonight) by switching the filter wheel driver to UNIDIRECTIONAL only.  This means the filter wheel always travels in the same direction when changing filters.  Using OMNIDIRECTIONAL could introduce some slight errors alignment, I guess sort of like backlash.  That may be the source of the problem.
Well written Insightful Concise
GergoB avatar
Do you use filter offsets? Perhaps redo your filter offsets.
Jerry Gerber:
Bad alignment would cause vignetting but not bad focus. Even though your filters are the same brand don't expect them to be parafocal. Even filters that claim they are won't be exact. A lot depends on the optical system as well. The best solution would be to determine focus off sets for all of your filters. If you are using something like NINA it's very easy to do this. Once you've set it up it will be automatic and transparent.
Jerry Gerber avatar
Jerry Gerber:
I do autofocus immediately after every filter change.  That works best for me.
Well written
Certainly an option, it just eats up more imaging time if you have a lot of filter changes.
Well written
Jerry Gerber avatar
True, but it ensures good focus for each filter. Also, sky conditions are continually changing, a 2nd reason to focus after a filter change.
Linwood Ferguson avatar
When I first got mine and temporarily had screw in filters (Chroma) if screwed in all the way, they would literally drag sometimes when rotating.  I had to actually loosen them to make them fit.  Chroma's are a bit thick, but… make sure your filter wheel, say at some angle(s) of operation, are not failing to turn properly.
Jerry Gerber avatar
Linwood Ferguson:
When I first got mine and temporarily had screw in filters (Chroma) if screwed in all the way, they would literally drag sometimes when rotating.  I had to actually loosen them to make them fit.  Chroma's are a bit thick, but... make sure your filter wheel, say at some angle(s) of operation, are not failing to turn properly.
When I installed the filters they seemed to fit perfectly, I tightened them snugly but not too tight.  I recalibrated the EFW and switched to Unidirectional--I am hoping this resolves it.
Jerry Gerber avatar
Everything seems good now.  I switched the filter wheel driver to UNIDIRECTIONAL and re-calibrated as well, EFW behaved as expected last night.
Well written Concise
Arny avatar
Jerry Gerber:
I had that problem of using omindirectional wheel drive, but it rather creates donut shapes in your flats that play out badly on the image - not so much defocussing
Arny
Jerry Gerber avatar
Arny:
Jerry Gerber:
Arny
Yeah, I'm really not sure why the stars would get defocused if the filter wasn't precisely lined up but the problem seems to be gone now.  If it returns I'll have to hunt for other causes...
Why Do Subs Fail to Register in Pixinsight?
Withdrawn post. I discovered many of my subs were not focused well and this is why they failed. When I eliminated the ones that didn't have good focus, all of the other subs registered successfully.
Directly relevant; addresses focus issues causing failed subframes during imaging sessions.
Apr 21, 2023
Focuser trouble when NINA starts
Hello, I’m new to NINA (was using ASIAIR before), I was able to connect and set everything and to perform two nights of imaging. Here is my issue, the last two times I turned all my equipment on, my focus was lost (I mean stars wereway out of focus, ...
NINA software focus issues may relate to remote imaging focus problems.
Sep 3, 2025
Focus Issue with OIII filter on edgeHD 8
Hello, I recently acquired a 533 mono camera and have been collecting some test shots weather permitting. I use Zwo Eaf for focusing. With the Luminance filter the focus point was very close to my previous configuration (osc camera + cls filter). Las...
Focus issues with specific filters directly matches green filter focus problem.
Aug 12, 2025
Filter wheel for OSC?
Hi All. I’m wondering if anyone is using an EFW with a OSC camera? I have an ASI533MC Pro and use the Optolong L-enhance for nebulae and then the Astronomik L3 for broadband targets (both 1.25” versions). I had to swap the filter last night and it oc...
Filter wheel solves manual filter swapping problem author describes.
Jun 25, 2023
Optec Leo for Epsilon
I pulled the trigger on this focuser for my Epsilon yesterday. (the light leaks in the stock focuser were making me paranoid) I'm super excited about it, but also 99% certain I can screw it up. Any tips for feedback from those of you that've ...
Filter wheel issue caused focus problems; relevant to focuser installation concerns.
Jul 18, 2023
