Takahashi FS60cp electronic focuser
6 replies218 views
vikas chander avatar
HI,
i am trying to install an electronic focuser into the new Takahashi FS60cp but cant find a solution ?
any ideas are welcome ?
thanks
vikas chander
Iosif Bodnariu avatar
Unfortunatley, the FS60cp focus plate is different- It has only one screw ...
Jay Hovnanian avatar
Vikas,  Find someone who possesses 3-D Printing design skills.  Lots of EAF holders already exist for other scopes.  I utilize one myself.  From what I am looking at, it doesn't seem overly complex, other than modifying the flexible EAF transition connector.  Jay
Habib Sekha avatar
Willem Jan Drijfhout avatar
I have a Pegasus focus cube on the FOA-60 (same as FS-60CB). Works with the default mounting plate that comes with the focuser.
Wolfgang Reissenberger avatar
I'm using the StarlightInstruments PDSM focuser on my FS-60CB. In addition, you need a MEF-3 micro focuser and an Optec FocusLynx controller.
What I really like with the PDSM is, that it has a very compact positioning of the motor and it needs only one (ethernet) cable to connect. That's why I am using this one or the HSM focuser on all of my scopes.
Cheers
Wolfgang
Finding targets in light polluted skies - any tricks?
Hello everyone! As you can guess from the title, I’m still fairly new to this hobby. I have a tracker but not a go-to mount unfortunately, so all my targets so far have been the classic easy ones to find - the ones you can pretty much see with the na...
Electronic focuser installation may relate to light pollution observing techniques.
Mar 24, 2026
Lunt LS50tha and ASI585MC Pro compatibility and focus issues
Did anyon try to pair up Lunt LS50tha with ASI585MC Pro? I am having focus problem and I am not able to where if I use say ASI174MM mini then all works well. I do believe I have correct backfocus setup for ASI585MC Pro but still. Any idea clue? wheth...
Focus issues with equipment similar to Takahashi telescope systems.
Dec 18, 2025
EdgeHD 8 Focus Point Moving
Hello! Curious if anyone can assist here. I have an EdgeHD 8 using a ZWO EAF. Been using it fine for well over 2 years now and everything has been fine until recently. It can’t seem to find focus anymore using Nina/Hocus Focus. What happens is the fo...
Electronic focuser problems with EdgeHD similar to FS60cp installation.
Mar 15, 2026
