First steps in my Dual-Setup
Multiscope Setup 2 replies145 views
CCDMike avatar
Hi all,
The goal is to use my two cams (OSC and Mono) to double the exposure time per night. With the ASI 294MC at the 130 PDS I do the RGB stars and with the QHY294MM the luminance and/or narrow band at the 8" f5.
I have the first step, mounting and balance, behind me 😃.
Now comes the hard part. The exact alignment of the image field and (and this is the hardest part i guess) the exact same alignment of the spiders. Otherwise there will be multiple spikes😝.
Of course, this is best done on the star. Unfortunately, the weather forecast gives nix so quickly. In addition, I still have to deal with the control of both cams in NINA.
I am open for any advice.
Cross your fingers for me!
Mike
Reg Pratt avatar
Very nice! I too am bummed they dropped dither sync in Nina v1. 11. I ultimately switched to Voyager to deal with my dual rigs.
Michael Taube avatar
Beautiful setup!!!works for many applications!
Getting rid of divergent spikes with a defocused star
Hi Folks, I would like to share a little tutorial with you about the alignment of the secondary mirror vanes. The goal is to create nice and narrow diffraction spikes without splitting towards the ends. This applies to all Newtonians with adjustable ...
Tutorial on aligning secondary mirror vanes to eliminate multiple diffraction spikes.
Aug 19, 2023
Ideas for handling different setups - how do you deal with your equipment
Hi all of you, over the last three or four years, since I began to do astro photography. I developed a method of handling my equipment. This works for me. But before I write some lines about it, I want to explain the reason for this thread. Astro pho...
Methods for managing and organizing multiple telescope setups and equipment.
Aug 27, 2023
