Nikolaos Bafitis avatar
hello I have recently purchased the seestar s50 and taken a few images with it and stacked and processed them using siril, but I have noticed that they always come out with a lot of noise. How can I avoid this?
Jean-David Gadina avatar
Nikolaos Bafitis:
Do you take dark frames?
If so, how many?
Jean-David Gadina:
Nikolaos Bafitis:
If so, how many?
I don’t know how
Use noise reduction, it is in Siril under the image processing tab but even better, grab a copy of Graxpert. It's free and does a wonderful job of reducing noise.
I believe when you use SeeStar in Autorun mode it makes and applies the needed calibration frames automatically but you'll still need to reduce noise in post.
Stéphane Mee avatar
Hello Nikolaos,
There is a good tutorial from Siril on S50 data here: https://siril.org/tutorials/seestar/ and here too: https://www.youtube.com/watch?v=syCVl1fDLTk
For the noise reduction, Graxpert is a good option. If you can install the latest Siril BETA and Graxpert, it is now fully integrated.
If you want a comparaison with Pixinsight, I could process your data if you want so you can compare.
Cheers
Stéphane
Helpful Respectful Supportive
Bob Lockwood avatar
Since you have Photoshop, do you have the Actions tool set? Lots of good plug-ins in it for just $22. Reduce noise is one of them.
Astronomy Tools Actions Set by ProDigital Software
Michael Diaz avatar
The S50 automatically takes dark frames.
How many subs are you shooting? The more subs you take, the less noise you will end up with once you stack them in Siril or other software. There is a point of diminishing returns but generally the more total time you spend on a target, the less noise you will end up with in the final stack prior to beginning to post process your images. As others have mentioned, there are different scripts and software that you can use in your processing workflow. I personally use Graxpert in my PixInsight workflow.
Michael Diaz:
ill probably try to take more data and use graxpert
Does Seastar Got 4K Resolution Mode?
Hello and welcome. I'd like to ask everyone who is using the Seastar or who knows about the current firmware update of the Seastar. I heard from social media that the Seastar app just got a brand new firmware update recently, with a few improveme...
Seestar S50 camera specifications and capabilities relevant to noise issues.
Aug 4, 2025
Seestar 50 Unstacked Practice Data
I am thinking about getting a Seestar 50 to play around with while my regular rig is imaging (Askar 107PHQ/ASI2600MC Pro). I am trying to be realistic and manage expectations. I know that the S50 images won’t be as robust as those from my main rig, b...
Unstacked practice data may show noise patterns in raw Seestar 50 images.
Nov 30, 2025
Seestar S50 Lunar AVI practice files
I am preparing for the arrival of my Seestar S50. I already use Pixinsight for DSO processing (from my main rig) so I’m okay with that, but want to get set up for external lunar/planetary processing so that I can image the moon with the S50. I work i...
Lunar imaging files could demonstrate noise characteristics in Seestar S50 output.
Dec 29, 2025
How Does Seastar's New Flats Work?
Hello and welcome, I'd like to ask everyone who is using Seastar and has taken flats with it or has experience, how does this work? I recently managed to do the flat shots with my Seastar, but there's one thing I don't know about this. Li...
Flat frames help reduce noise and artifacts in astronomical image processing.
Jul 28, 2025
Need Help Processing Comet Images Taken With seastar
Hello everyone! I’m reaching out because I’m feeling a bit lost when it comes to processing comet images taken with the Seastar. This year, I captured two different comets, but I'm not sure how to process them. I tried following the tutorial from Dee...
Comet image processing with Seastar addresses similar noise reduction challenges.
Sep 3, 2025
