weird object captured from plane
10 replies512 views
satellite?
Multiple choice poll 14 votes
43% (6 votes)
57% (8 votes)
Nikolaos Bafitis avatar
Hello, I recently went on a flight on which I decided to take my camera to attempt to take pictures from a plane window and noticed that I captured what seemed to be a satellite but was wondering if it was possible with a wide field lens and only 10km above seal level.
I uploaded the image below but as you can see based on the other stars the plane was shaky and so it would actually be half of what it actually is.
Yuxuan avatar
Nikolaos Bafitis:
If you look hard enough all stars are doubled and each image has tiny ghost wings. Satellites are very far away and appear as point sources even for planewave’s large CDKs. I don’t think you could have captured its shape using a cellphone.
It's a bright star or planet. If it was moving relative to the background stars it could have been the ISS. All your stars are trailed and have wings as mentioned yuxan. It's not something weird at all.
Most likely the ISS.
DavesView avatar
Were you over New Jersey? smile
Oscar H. avatar
I think it was a planet, plus some astigmatism (caused maybe by the window of the airplane, maybe you were at a rough angle when taking the pic, or maybe this a crop of the edge/corner of the photo, which should have more aberrations and stuff than the center the photo)
but the real question is, what did the OP see (with his own eyes) that made him take a picture? did he see a moving thing, or a stationary thing? or was he randomly taking pics and he saw this bright object in the frame?
the shape of satellite is impossible to take with a phone (unless it's the ISS maybe, and only the rough shape of it); the only guy (amateur APer) I ever saw taking images of the shape of sats, used a big SCT and planetary cam and even then, the sats were only like 20-30 pixels in size (maybe less)
Yuxuan:
Nikolaos Bafitis:
I know it’s doubled and also I captured it with a camera, I don’t think it’s a satellite but my best guess is it’s some kind of drone
TiffsAndAstro avatar
Looks like iss
But same pattern is repeated like bug splatter
Nikolaos Bafitis:
Yuxuan:
Nikolaos Bafitis:
mmmmm, probably not at that attitude
Oscar H. avatar
I wonder if the OP was actually talking about the line near the center of the photo; in that case, it can be a satellite
otherwise, if the OP is talking about that bright thing, it's a probably a star or a planet, because all the other stars in the image have the same winged and doubled look to them
Ian McIntyre avatar
Hope you don't mind. I took the liberty of downloading your image. I then plate solved, applied a predictive stack, stretch, zoom, ubercrop, and AI enhancement yielding the following result of the object in question.
Sorry its so blurry. I'm new to this style of processing. And you were in a plane.
Helpful Respectful Supportive
Review of the QHY5III678M for ground-based satellite imaging
This is a review that shows the performance of the QHY5III678M planetary camera for ground-based imaging of satellites, I will showcase the specifications of the camera and example images I have taken with it of several satellites. I also want to kin...
Reviews ground-based satellite imaging techniques and camera performance specifications.
Jan 12, 2026
