Help with WBPP "no frames found after calibration"
2 replies194 views
Oscar H. avatar
I'm getting this, and I'm unable to stack
these are my lights:
(600s lights are named "Venus", but that's incorrect, just something that the ASIair does when you slew from a named target to an empty piece of sky - the name for the captured subs don't change after slewing from the named target; I guess the AA should've named it FOV, but I don't think this will affect stacking in any way.)
my flats:
this is what calibration shows:
I was trying to stack 300s lights with 600s lights, and I have all the correct flats per session, and the correct darks per exposure time, and biases
but it has a problem with my flats, "no frames found after calibration"
Never use WBPP.
wsg avatar
There is a tab called Calibration Exposure Tolerance it should be set to "tolerate" both exposure times.  Yours is at 2, it should be 300.
Read more, post in the forum less.
Can't catalog search using Photometric Color Calibration in PixInsight...help?
I'm trying to do PCC in PixInsight, however I can't seem to search a catalog for my target, so it fails each time. Anyone have this problem?
Unrelated; addresses WBPP frame calibration, not PCC catalog search.
May 27, 2023
My Darks are Lights!
2 nights ago after capturing all my lights I stopped the sequence and set up a new sequence to capture my dark frames. I clicked the "dark" box so it would set up a "dark" folder (which it did). I put the front cap on the telescop...
Frame calibration problems during stacking workflow similar to author's issue.
Jul 26, 2023
Flats undercorrecting vignetting
Hello all! I'm facing issues trying to calibrate my light frames with flats, they seem to be undercorrecting the vignetting on the frame: The equipment I'm using is the following: - Modificated Sky-Watcher Quattro 250P OTA - Sharpstar 1x GPU ...
Relevant to flat frame calibration and vignetting correction issues.
Aug 6, 2025
