Heavy duty mount for a 40-50kg payload and other upgrades on the scope.
9 replies386 views
Luka Poropat avatar
Looking for your suggestions on this, please if you write a model of something do add few reasons why you are suggested it.
The telescope is a 16"/40cm F4.3 newtonian, without rings, dovetail, focuser etc. (just tube + mirrors & spider) its 31kg. The primary is a 2,5cm thick Pyrex optically excellent mirror sitting on "dobson style cell" a piece of carpet. The current focuser hole is 100mm/4" diameter and the secondary is around 150mm/6".
For the testing purposes it will be tested as is but in the future modifications will happen, such as potentially sandwich CF tube, 18p primary cell, revised spider and secondary holder and  new focuser.
Ruediger avatar
I recommend a 10 Micron GM 2000 HPS (50kg payload) or a 3000 (100kg payload).
They can easily handle it and no guiding needed.
Ruediger
I was going to get one of those but I missed my chance at the offer price and I can't really justify the outlay given my locale but if I were to go for a large sized scope this would be my choice (and much cheaper than 10Micron):
Trident GTR - 50% Deposit - Preorder Special Offer - Free Shipping - D – JTW Astronomy Webshop
Spacetime Pictures avatar
Planewave -L
ASA DDM
would be my choices
midnightsnacks avatar
AP has 1600’s in stock.  100kg capacity.
Ashraf AbuSara avatar
Very intrigued by this. Lots of possibilities.
Daniel Cimbora avatar
Second Ruediger's recommendation for a 10Micron.  My experience with my GM2000 has been, well, stellar [/rimshot].  Imaging without the need to guide is so liberating, though you may not be able to do that with a Newt OTA.
Plenty of great other choices, especially Planewave.
Supportive
Ani Shastry avatar
Definitely recommend a PlaneWave L-500 with an equatorial wedge if you have sufficient space for that setup. Otherwise an Astro-Physics AP1600 GTO with encoders.
John Hayes avatar
The 10 Micron or the Astro-Physics 1600 mount would work well.  You would have to make sure that you have enough pass through space for a Newt on a PW L-series mount.  That mount can also move quite rapidly so you'd need to make sure that the primary is well secured to insure that it wouldn't get pulled out of alignment.  The other issue with the L-series monts is that your scope will need to be perfectly balanced about all three axis, which requires some care with a Newt.
Helpful Insightful Respectful
Alex Nicholas avatar
AP1600GTO would be ideal, as would a 10 Micron 2000 GM2000. I wouldn't bother with either without encoders…
Your other option would be the Trident GTR/GTS…
ONTC Tube Foam Sandwich Compression and Solution
I’ve been using a 10” TS Optics ONTC Newtonian as my primary imaging scope for a few years now. Overall it’s a great scope and I’ve been very pleased with its performance. It is, however, not without some issues. One issue which has plagued me from d...
Discusses ONTC Newtonian tube construction, relevant to your telescope design considerations.
Oct 22, 2025
