What was your experience switching from ASI2600MC to ASI2600MM with exactly the same scope?
Rick VereginFrédéric RuciakDaniele BorsariArun HTony Gondola
36 replies1.5k views
Frédéric Ruciak avatar
Hi, I am planning an upgrade of my current astro setup (TS CFAPO90F6, ASI2600MC, AM4, guiding with evoguide 50ED ZWO290MM) and I am most probably going to upgrade to a NEwtonian 150F4 (may be TS UNTC150F4) to stay light for the AM5.
I started astrophotography with the OSC ASI2600MC and I learned to use it for NB processing too. And I am really satisfied with this camera.
But I really would like to ear about those of you who switched from an ASI2600MC OSC camera to an ASI2600MM mono camera keeping all their other equipments
On the paper, the full resolution is native and not generated with the debayering algorithm (said to be equivalent to 30% better resolution), the sensitivity is improved and using a good filter wheel and NINA it should be almost transparent and automatic while I am sleeping ;-) I'll most probably get a better signal for a given amount of hours or photon capture. But I can compensate with more hours of OSC camera.
But in the real life, for those who switched, have you been estonished, amazed, enthusiastic or neutral when you finished your first processing with your new mono camera? Have you been able to see the obvious difference? Would you recommend me to switch to ASI2600MM as my next move without a doubt putting all your persuasion on it? or not?
I am impatient to learn from your own real experience.
Thanks in advance, Frédéric
I would love to see that as well. It seems on paper that the resolution and S/N difference should really be apparent but in the tests I've seen, it doesn't seem to be. I believe Cuiv did a YouTube video doing exactly such a comparison.
Thomas Rider avatar
As a 2600MC owner count me curious
Daniele Borsari avatar
I don't own neither the ASI2600MC nor the ASI2600MM, but I switched from the ZWO ASI533MC Pro to the Player One Ares-M, two cameras that use respectively the color and mono versions of the IMX533 sensor (basically the same sensor as the IMX571, just smaller).
With this upgrade I also added an 8 position filter wheel and an electronic focuser. My telescope (or to be precise my lens) is the Samyang 135mm f/2.0.
I can tell you that the difference in terms of SNR using narrowband filters is night and day, of course in favor of the mono camera. The difference is a bit smaller with broadband filters and LRGB, but it's still there.
I also found that adding a filter wheel and a focuser (I set up filter offset to focus once with luminance and not with every filter) helped everything being more automated. I can change filters without waking up and unscrewing the imaging train and I can also set up a sequence to shoot a broadband target until the moon rises and then switch to a narrowband target.
IMO it makes imaging different and more impactful especially when the narrowband single subs are rolling in. I could achieve similar (a little lower, but still very high) SNR levels with the H-alpha filter and mono on NGC 1499 with 45 minutes of exposure, to the red channel of 20 hours of exposure with the L-eNhance and OSC.
The only thing a bit more difficult is shooting flats for every used filter for each session instead of just one set of flats (and also managing all the different files).
This was my first light of the mono camera on NGC 1499:
And this is a different work I did last year with the ASI533MC Pro:
If you have the budget and you can stand the work of multiple filters, you'll be very satisfied.
Daniele
If I were to chose between the two shots I'd chose the second one (IMX533C) without even a second glance. In all fairness they shouldn't even brought as comparison, completely different imaging targets. I have done some comparison between IMX294MC based cameras and its monochrome brothers and as far as luminance goes the difference is nowhere close to 1:3 that one would be expected by the pure specs. But then again the tests wheren't side by side as by definiton this is rather impossible (well, maybe with a beam splitter…). Obviously pure NB work gets a significant benefit in going mono but that isn't my aim so I'm sticking to OSCs.
What I tried to point out is that with such a short integration, a little bit over 2 hours, the first shot (IMX533M) is close (what I mean with close is that the emission part of the nebula has a similar SNR) to the second shot (IMX533C), with 21 hours of integration with the L-eNhance.
So, I stacked 9x300s frames from last year (45 minutes total) to compare the master to the 9x300s frames in H-alpha from this year (45 minutes total).
The FOV is a bit smaller due to cropping after registration.
I want to note that the environment conditions were very similar, the object was near the meridian in both cases, there was no moon, no haze and it was shot from the same location (Bortle 5).
Also with a monocrome camera and narrowband filters you'll have a purer signal (especially in the Oiii), with no leakage from the bayer mask.
OSC: ZWO ASI533MC Pro, Samyang 135mm f/2.0 (stopped down to f/2.8), Optolong L-eNhance.
Mono: Player One Ares-M, Samyang 135mm f/2.0 (stopped down to f/2.8), Astronomik H-alpha CCD 6nm.
OSC master light:
OSC extracted red channel:
Mono master light:
Helpful Insightful
I would contend that a 12nm passband filter is no match to a 6 nm passband filter.
I think andrea makes a good point. For this comparison to be valid, I think the same filter has to be used, preferably on the same night.
Cuiv's video on the subject may shed some light:
https://www.youtube.com/watch?v=CooWNVq6rj8&t=1016s
Not the perfect comparison but interesting.
IMHO what Daniele is showing is that mono camera are intrinsically more efficient that OSC and this is not only rationale for RGB but even more for NB. (As far as I know with an OSC I have to recombine the RG or GB channels to retrieve the Halpha or O3 bands) But extending the time of exposure to compensate can be done.
When I compare the images of Daniele on pure details I clearly see an advantage to the Mono camera.
But it is not striking me and I see that there is not a obvious consensus ;-)
There's no doubt about the efficiency but for for me, it would be a very large cash outlay to go from OSC shooting dual band as I do now, to a complete mono setup. I believe the 533 is the least expensive camera at $900.00, add the filter wheel $260.00, filters will run at least $630.00 or a lot more and lastly an EAF $200.00. That's about $2000.00 at a minimum. To be fair, the EAF and the filter wheel would have some utility in OSC but I also start thinking about some very nice OTA's I could buy with that same amount of cash. For me at least, it's a hard sell.
D. Jung avatar
Just finished first light with the ASI6200 and was also very interested in the difference from MC to MM.
Comparison of single shot 600s with Antlia Edge Sii filter. Everything the same, except in the left ASI533MC, to the right ASI6200MM (cropped to show the same FOV).
V avatar
This makes me very anxious to get rid of the CFA on my 2400.
Thomas Rider avatar
D. Jung:
Amazing SNR difference
Rick Veregin avatar
I have no deepsky experience with the 2600mono version, but have used the 2600MC for NB for years now, and am really happy with it. I did make a deliberate decision to go with OSC, but did my research first. So there are a few points I can make based on my experience, and a lot of reading.
Simplicity and cost was a factor–I hate doing flats and they can go wrong in so many ways. The thought of doing flats for LRGBHaOIIISII gave me pause. Also 7 filters! I now use three, an SO and an HO filter with my OSC, plus a LP pollution for WB. But note to get here, I went from the L-eNhance, to L-eXtreme, to L-Ultimate for HO as the technology got better in the filters. For SO and LP I also upgraded, so have with upgrades bought 7 filters. If you have 7 filters to begin with that you want to upgrade, you may need deeper pockets. And of course you need an automated filter wheel with mono.
My sky conditions, especially seeing change dramatically over a night. With mono, you have to worry if the seeing was worse with one color than another you will get halos, so you need to correct somehow for that. For things like comets that are moving, mono would be more painful. And for planets, an OSC is so much easier since the planets are rotating and seeing conditions are so important.
As to signal comparison.
Say you have a patch of Ha in the sky. For mono NB you get 4 pixels of Ha, compared to 1 pixel for the OSC. So for Ha, OSC will need about 4X longer exposure to the same S/N. But note, at the same time you are capturing 3 pixels of OIII with the OSC, but you are getting no pixels of OIII in mono. So if there is OIII there in that patch as well, then to capture that with mono you would need to half your time on Ha, then switch to OIII for the other 1/2 fof the time (or whatever fraction you want). Of course you would want to do this anyway, unless you are just making a red Ha image, as you want to color balance to get a full color image presumably. This halves your mono Ha advantage to 2X since we will use 1/2 the time for that, and 1/2 the time for OIII, so 1/2 time x 4/3 pixels= 4/6 the OIII signal compared to the OSC. This means you would need to spend 1.5x more time on the OIII with the mono camera. So the mono camera has a 2X Ha advantage and a 1.5x disadvantage in OIII. There is a difference, but it is not huge.
Personally I find many nebula are super strong in Ha, but relatively weak in OIII. So I can tolerate the fewer pixels of Ha to make my signal, and take advantage of the strong OIII signal I get at the same time. Of course, with mono you can choose to shorten your Ha and lengthen your OIII to adjust, which you cannot do with an OSC camera. Still, if you are interested in OIII, OSC is not far from mono, if you are interested only in a mono Ha image, mono is a clear winner.
Now, using NB filters with Bayer filters does loose some signal, maybe 20%, compared to mono. On the other hand, debayering averages pixels, so it improves S/N, kind of a partial binning if you like. So these two factors are probably close to a wash.
Note Blair McDonald has a great article in JRASC (the Journal of the Royal Astronomical Society of Canada), April 2022, P79. You may be able to find a copy in a local university library, I can't share it obvious due to copyright. It used the 2600MC and MM in RGB imaging, and found that in that case, generally there is slight advantage to OSC over mono. It does again depend on the target. He does all the math as well, it is a very well done article.
Regarding resolution, you must take into account your particular setup, focal length and pixel size, as well as seeing.
If you are totally limited by seeing and not by your pixel scale, then obviously no way a mono camera can do better in resolution than an OSC camera, it is the seeing the decides what you resolve. Case closed. In my own case, my deepsky work is always seeing limited, since I am at long FL (1430 mm), this is to be expected.
If your pixel size is determining your resolution, the resolution is not as bad as one might naively think with an OSC. First, the debayer actually can recover some detail, there are lots of scientific papers on debayering and finding better algorithms, since it is critical to consumer cameras. There is even a debayer drizzle. Further, every frame you take is slightly offset from the last one, even with the best guiding. This helps fill in the gaps. All one needs is a shift of 1 pixel to fill in the gaps. If you dither this will do it as well.
I do planetary imaging with an OSC and am very happy with the resolution I get there, again my seeing, even with lucky imaging, is my biggest limitation.
Finally, I have been in this astrophotography journey for about 8 years now. My plan has always been to start simple stupid, and then work my way up if I saw the need. My experience is for spending money, at least if you want to do long FL imaging, is to get the best mount you can possibly afford, then see what you have left.
I hope this helps.
Rick
Hi Rick,
thank you very much for your comments. I found a free access to your article here and the reading is truly interesting as it is going beyond tradtional analysis. I recommend it.
CS Frédéric
Rick Veregin avatar
Frédéric Ruciak:
Hi Rick,
CS Frédéric
That's interesting, I had though one had to be a member, like I am, to access it. It is a very good article, but am waiting for his follow up with NB...Great you were able to read it.
Yes, but I guess the rationale is playing even more in favour or Mono camera this time. CS Frédéric
Rick Veregin avatar
Frédéric Ruciak:
Yes, certainly for Ha only. For a mixture of Ha/OIII in a target it will be reasonably close I think, though it will obviously be better in mono to some extent, and again in mono one can tailor the exposure times in Ha and OIII depending on their relative strengths in the target, to do even better. I thought I had seen a good video that did the analysis of mono and OSC in a systematic way for NB, but I can't find it right now. Most videos seem to be just "my" opinion pieces, without any systematic data to back them up.
Arun H avatar
Rick Veregin:
This analysis is problematic for the following reasons:
  1. If debayering truly increased SNR, there is nothing stopping you from doing that with a mono frame and getting the same advantage but much better SNR. For example, you could simply split your single mono frame into two (or four) frames, each capturing different (and uncorrelated from a noise standpoint) pixels and basically get two or four times the signal in the same time with the mono as with the OSC. So most definitely not close to a wash.
  2. If different signals have different strengths, in mono, you'd simply tune your total time on each filter to match. You don't get that flexibility with OSC.
To the extent this is a problem (in most cases, for long enough integrations, the seeing will average out), taking RGB stars corrects for it.
In the end, for narrow band, from a pure SNR standpoint, mono is a pretty clear winner. Which is why most remote imagers tend to use it.
But SNR is just one consideration. There are many others. And for some of these, OSC will be better. Which is why there rarely is consensus. What makes sense for one person may not make sense for another since the requirements, and the emphasis on specific and individual requirements is different.
Helpful Insightful
Brian Fowler avatar
I've been imaging with a Poseidon-C (same sensor as the 2600),  Askar FRA600 with L-ultimate and Askar D2 filters for about 10 months and just got a Poseidon-M, filter wheel and Antlia 3nm SHO and pro series LRGB last month.   I don't have any data that you could compare apples to apples, but since I got the mono setup, I haven't used the OSC.  IMO the data for narrowband is cleaner and the images are sharper, but I feel OSC could close the gap with a lot longer integration.  For Broadband, I don't feel there is a whole lot of difference.
The automation in Nina has made setup easier with the Mono vs OSC.  Using the L filter for plate solving, autofocus, and polar alignment speeds things up a lot.  The versatility with mono is another plus being able to shoot whatever band you want.  I've only had mono for a month now so the fun factor may wear off some, but I would go to Mono again in a heartbeat.
Rick Veregin avatar
Arun H:
Rick Veregin:
1) Regarding the effect of debayer, this is from the scientific papers around bebayer, not my opinion. It is very much like a binning process, though not as harsh on resolution as 2x2 bin, but certainly with mono you can do a bin to gain an advantage, but one could do the same for the OSC and get almost the same benefit. Unless you are saying binning a CCD camera, that is a different kettle of fish. Anyway, the OP is interested in the same CMOS camera, mono vs OSC, so CCD is a different topic.
2) I did point out one can tune the time with mono, so agree with you there. But again, if your focus is on Ha, then mono wins easily.  Let's say though you need more OIII integration than Ha. Lets take a 4 pixel patch so we can compare a total 1 hour integration and say the Ha signal is 40 e/px/h and the OIII is 10 px/h. For mono signal is 1/4 hr Ha + 3/4 hr OIII, or 40 e/px*1/4h* 4px + 10e/px*3/4h*4px = 40+30 = 70 electrons, and you have a nice balance of OIII and Ha signals. For the OSC the signal is 1hr Ha and 1 hr OIII, or 40e/px/h*1h*1px + 10e/px*1h*3 px = 40+30=70 electrons. So a wash, aside from some bayer filter losses. Of course, if OIII is strong and Ha weak, the mono camera with tweaked exposure does better to create a balanced image. It depends on the target and your imaging goals.
So mono comes up big on the Ha side when Ha is weak, especially if you tailor the exposures, but doesn't do much better when OIII is weak. And doesn't do better for WB targets.
Totally agree with you there are many many other factors to consider. And it points out well, whatever option you chose, whether it is mounts, cameras, filters or optics, choose it based on your imaging environment (LP, seeing, fraction of clear nights in a year), on the targets you want to image, and then image on the targets that your setup is suited to. This is why so many of us have different cameras (I have two OSC and two mono, then there are my DSLRs), optics (I currently have three), etc...
Helpful Insightful
Arun H avatar
Rick Veregin:
I should be more clear with what I am saying here. The 2600MM camera, as a specific example of (say) H-alpha, will capture 26 MPix of data, each pixel of which is independent from a noise standpoint with respect to its neighboring pixels.
The 2600MC will capture only 6.5 MPix of noise independent pixels, the rest reconstructed through debayering. These are not independent from a noise standpoint, and that is a key factor.
Now, if debayering was the solution to SNR (as opposed to resolution), think about what I could do with the 2600MM frame.
I could split that into four 6.5 MPix frames, each noise independent of the other (since the photons incident are both spatially and temporally random), debayer each of those, and essentially get four times the signal of the 2600MC in the same time.
This has nothing to do with CCD versus CMOS, but is inherent in the basic statistics of photon capture that are independent of the recording method. Think about it - if it was truly possibly to get the same signal to noise by splitting your subs and debayering them, why stop at four? Why not eight or sixteen?
D. Jung avatar
Demosaicing does not increase SNR. It fills in the missing pixels for each color using neighboring pixels. That process is noisy. The SNR of the original pixels does not increase and the SNR of the reconstructed pixels is most definitely not increased either buy this process.
Concise
Almost like christmas eve when I was a child…..
Countdown T-48 hours until I get my new ASI2600MM Pro 🤪🤪🤪🤪🤪
Directly addresses switching to ASI2600MM; provides real-world experience comparison.
Jun 13, 2023
Where next with my AP gear?
I would like to tap into the wisdom and experience of my AB friends again. For the past two years, I have been imaging with a largely "settled" suite of rigs; a Nikon 200mm f/2 camera lens, a TS Hypergraph8 at f/3.2 and a GSO RC8 at f/8. Wi...
Author uses both OSC and mono ZWO sensors; mono upgrade experience directly relevant.
Apr 9, 2023
Old models vs. new models
Hey again, So now with many cameras coming out i keep asking myself, are the old models we have no longer good? Should we keep those old models? Should we only buy new models? I have 2 models of that new sensor, IMX571, but i also have that 290 mono ...
Discusses camera model comparisons and switching between similar sensor options.
Apr 16, 2023
Advice Needed - To jump or not?
I've been doing astrophotography for a number of years. I started with OSC and then switched of Mono. I'm under Bortle 4 skies using a 120mm refractor. I doubt that I'll ever be good at processing but I seem to get reasonably good data. I...
Author considering Mono camera upgrade; this compares OSC to Mono camera experiences directly.
Feb 26, 2023
ASI 533MC vs ASI 533MM, what compromises for broadband ?
Im starting this as a question im still asking myself, I have both experience with OSC and Mono cameras (all high end) and I am fully aware that going mono will always yield the better results but I am also aware of how good OSC cameras are especiall...
Direct experience comparing color and mono cameras in same setup.
Apr 19, 2023
