Collimation Issue
1 reply78 views
Ajith Everester avatar
I have been struggling with the collimation of my Skywatcher Quattro 300P for past 3 years. bought all kind of collimators and tried everything. changed my focuser to moonlite.
I think I couldn't achieve the best in the secondary mirror. Can anyone tell me what is happening with my secondary? I have tried all my best to put is inside the green circle but however it finally becomes this.
Your secondary is slightly rotated relative to the focuser, you can tell that because it's not perfectly round. This is the hardest adjustment to get perfect just because of the way most secondary holders are designed. I think it's possible that all the time and gadgets are making you over think this. Have you done a star test? Are the rings concentric at high screen magnification? Are you having a problem with star shapes or irregular illumination that's effecting your images? That's the bottom line, it will probably never be absolutely perfect in some collimation gadget, it's your images that really matter.
Helpful Insightful Respectful
Odd "circle" in imagery when taking photos
Hi all, Starting with: This is a 12” newtonian (1200mm), with a Poseidon-M connected to 50mm (round) filters and an OAG-MAX (with a coma corrector) - 56mm back focus So I’ve been banging my head against a wall trying to figure out what this is… I fir...
Secondary mirror alignment affects image quality; directly relevant to collimation struggles.
Mar 13, 2026
Telescope Mirror Cleaning
Just sharing my success with what is probably a 'cheats' way of cleaning my 8" GSO Classical Cassegrain primary & secondary mirrors. The larger size of the 8" telescope tube allowed me to get away with it. Instead of the recomme...
Mirror cleaning may improve secondary mirror performance and collimation results.
Aug 10, 2025
