OCAL collimator
4 replies80 views
Menelaos avatar
hey guys! quick question! i recenty bought the OCAL collimator for my newtonian. I am not an expert at collimation and i'm still figuring things out. Through the OCAL collimation looks decent and through a collimation cap pretty much the same! However when i take flats it looks like it has uneven vignetting. Does the vignetting necessarily mean collimation is off? (The darker side in the flat frame is the front of the scope)
No
Menelaos avatar
No
I appreciate your reply but can you be a little bit more helpful than just a simple “no”? “No” means that i was right, uneven vignette does not mean bad collimation?
Yes, no means exactly that.
Menelaos, I see the same thing in my flats. I've checked collimation and it's spot on. There are a lot of things that can effect flat frames other than fall off so as long as your calibrated lights look good I wouldn't worry about it. I think a lot of times, looking at your flats frames is a mistake it can cause a lot of trips down the rabbit hole for no reason!
Supportive
SCT general optical alignment
I removed my 9.25 EDGE corrector plate retaining ring today to clean the inside edge where some fibers or lint had collected. When I did, I noticed the corrector plate is nowhere near the center of the OTA. There are four set screws that hold the cor...
SCT collimation differs from Newtonian; may not address vignetting issue.
26 days ago
extreme offset vignetting in flats and lights
This issue has persisted for a while now through at least 3 set ups and I honestly cannot for the life of me figure out what is causing this. Here is an image of one of my flats which displays the extreme offset in vignetting in my imaging train whic...
Directly addresses vignetting in flats; likely solution to your problem.
Nov 9, 2025
