Basic new install glitch
PixInsight Addicts 2 replies121 views
Dave & Telescope avatar
Hi folks,
I completed a brand new install on a Win 11 Pro machine and am unable to download updates from any non-PI repositories. This is version 1.8 .9-3 build 1612. I'm getting a 'network error 301' . Not sure if it's a windows 11 security thing or what. I don't see any obvious settings there that could be problematic.
Thanks
Dave
pfile avatar
couple of things to check are whether there are trailing spaces after the repository URLs - they need to be there.
another thing you can try is just use a browser, and append "updates.xri" to a repository name and see if the browser is able to download the file. for instance:
https://www.ghsastro.co.uk/updates/updates.xri
if that doesn't work i guess it's something wrong with your system.
rob
Thanks. When I looked at the repository entries in question again, there was an obvious typographical omission . I guess age is finally catching up smile
Regards,
Dave
New mini PC won't boot after remote imaging session
I got the new mini PC set up remotely and it’s blazingly fast, faster than I even expected. All went well on the first night of imaging with it. But this morning when I downloaded my data, I shut the computer off and it kept trying to reconnect. I as...
Windows 11 compatibility issue with imaging software on new system.
Sep 17, 2025
Seti Astro Suite Pro - Windows11 with Norton 360
A question for you all - in case you have already downloaded and installed the new Seti Astro Suite Pro! My workstation is running with Windows 11 and Norton 360 - downloading the Suite did only work after I had stopped Norton 360 protection. I was t...
Windows 11 security software potentially blocking network connections/updates.
Sep 18, 2025
Complete Windows 11 astrophotography PC build guide from scratch
🛰️ Windows 11 Astro Imaging PC Full Build Guide From Bare Metal to Stable Observatory Appliance This guide describes a complete rebuild from scratch of a Windows 11 PC used exclusively for astrophotography. The goal is not convenience. The goal is st...
Windows 11 astrophotography PC setup guide addressing system configuration issues.
Dec 18, 2025
