Hello community,
once again, your help is needed. This time, I am looking for your opinion about counter weights.
With my latest purchase of the TS 70mm Flatfield APO I do own a scope with a really great optical performance. My EQ6R Pro handles the scope easily, which I expected. Now, I also do a three point polar alignment at the beginning of each night, which increased the guiding performance a lot. But with the resulting quality of the images I get from this setup, I am a little dissapointed with my other scopes (I know it happens to the best of us :wink-1
. The problems I have with my Explore Scientific MN152 comet hunter will be part of another topic in the forum. Here, I want to adress the performance of my TS 8" f/4 Newton.
I know that the scope is not the most impressive one on the planet. This is ok and I can live with that. But there are some issues that I realized I may fix, that are not part of the scope itself or its optical design.
The three point polar alignment had a really strong effect on the small refraktor. My guiding graph is at least 50% better than before. So I expected the same for my Newton. But in reality, I only got at best 20% better performance. This is clearly visible in the star shapes of my images. So I thought about the reasons for that.
I am quite sure, the reasons are the weight of the setup and maybe the position of the counter weights. The scope is quite heavy (metal tube) and with guide scope, filter wheel, cameras etc. it may reach the limit of the mount. A solution could be to reduce the weight by replacing the guide scope with an off axis guider, maybe use a filter slot instead of my 2" filter wheel, etc. I can get creative here.
And after a long story, I finally reached the point of this question. I saw a lot of setups with additional counter weights to keep the center of mass closer to the mount itself. This makes sense so far. The question is, If I add another weight to reach this goal and so prevent the setup from oscillation, I am adding additional weight to the mount that may amplify the problems again. What is your experience here? Does this make sense and will it increase the performance or will it have no effect or is even worse? I do not own another weight (I have the two that came with the mount), and therefore cannot test it myself securely.
Thanks for your experiences!
Christian
Christian
