Charles Harris avatar
Hello to any and all,
I'm about to get into my 1.9 hyperstar for the first serious adventure since owning it for several years now.  What do you think is the best light pollution filter for the HS 8 v4? I have the ZWO ASI2600MC with Optolong L-Pro and L-Enhance already in my kit bag.
thank you
Charles
shenmesaodongxia avatar
Antlia triband works well for me
thanks very much..!
DARRELL DUBOSE avatar
Hi Charles,
I have the same setup; HD8, Hyperstar 8v4 and ASI2600MC Pro. My home area where I mostly image with the Hyperstar is Bortle 6 with some really nasty gradients from high pressure sodium lighting. I have used the L-Pro with good success. The color balance is well behaved. However, I have had some reflection halos around really bright stars such as Altair, but that might happen even without the filter. You didn't ask this, but I also use the IDAS NBZ dual bandpass filter (Ha-OIII) with very good results. I just posted 2 images, one with the L-Pro and one with the IDAS if you would like to see examples.
Let me know how your experience works out!
Clear skies,
Darrell DuBose
Thanks a lot Darrell.  I will take a good look at those images.  I already have the L-Pro.  I will give that one a try.  I am not sure if I have tried it yet.  I thought maybe I would ask around to see if those F2 light pollution filters were really needed for Hyperstar.  Maybe not it seems.  Thanks again.
Charles
Luigi Ferrari avatar
Per l’inquinamento luminoso io mi trovo bene con l’Antlia Quad Band 2”, dalla città con bortle 7, il mio Setup è Skywatcher 250P Quattro 250/1000 e Asi 294 Mc pro …
thanks very much Luigi.  I have considered that one too.  …still thinking after all this time… I need to get back to taking photos.
Keep or sell my Optolong filters?
Hi, I have Optolong SHO filters with 6.5nm and 7nm 36mm since 2018, and i used them several times in the past without nice results due to LP in my area, and later when i added 3nm filters i no longer using those Optolong 6.5nm/7nm filters anymore, bu...
Discusses Optolong filters for light pollution filtering in astrophotography contexts.
Aug 22, 2025
