10Micron GM1000 for Edge HD 9.25"
5 replies440 views
Jerry Gerber avatar
Hello,
I currently own a 10Micron GM1000 mount that is carrying a 130mm refractor at a dark sky site.  I am very happy with this mount and am getting excellent results shooting unguided 3 minute subs.
I am planning on putting a 2nd scope, a Celestron Edge HD 9.25", at a dark sky site and also placing it on a 10Micron GM1000 mount.
Will I still be able to shoot unguided (2350mm focal length) if I keep my subs at 5 minutes or less or, because of the longer focal length, would I need to guide?  The scope will be under Bortle 1 skies with often very good to excellent seeing conditions.
Sincerely,
Jerry Gerber
Well written Respectful
With SCTs guiding needs (or lack thereof) have as much to do with mount performance as mirror flop. Thus, depending on your focusing arrangements, you might or might not  need to guide. My bet is that you'll need to guide.
Jared Willson avatar
Due to the combination of the longer focal length and the movable primary mirror (that you won't be able to lock down since it's a remote site), I would be surprised if you could get away without guiding for exposures over 2 min or so. The mount is excellent, and the pointing model accomplishes a lot, but you are also asking a lot. I would plan on an off axis guider–no matter how good the mount. I would say the same about my beloved AP1100GTO AE.
- Jared
Well written Helpful Insightful Concise
Jerry Gerber avatar
Jared Willson:
Due to the combination of the longer focal length and the movable primary mirror (that you won't be able to lock down since it's a remote site), I would be surprised if you could get away without guiding for exposures over 2 min or so. The mount is excellent, and the pointing model accomplishes a lot, but you are also asking a lot. I would plan on an off axis guider--no matter how good the mount. I would say the same about my beloved AP1100GTO AE.
- Jared
I will be able to lock down the mirror permanently as the PrimaLuce Esatto 2" electronic focuser will be installed.  That will take care of image shift and mirror flop as I won't be touching the stock focuser.  All focusing will be done by the Esatto 2".
I'll also attach the Celestron OAG with a guide camera, but prefer to use the outstanding absolute encoders on the mount to guide.   The GM1000 manual says that no guiding is necessary up to 10 minute subs (my subs will be 5 minutes max) but it doesn't specify up to what focal length this is applicable.  So I guess I'll have the option ready to guide but will try to go unguided when possible.
astro10micron avatar
hello ,
You will find attached a beginning of answer to your question
http://www.astrosurf.com/blogs/blog/11-astro-10-microns/?page=4
It is compulsory beyond. I had gone out with a 3000mm focal tube
http://www.astrosurf.com/blogs/entry/663-suivi-10-micron-avec-le-vmc260l-focale-native-de-3000mm/
bonne journée
bon ciel
BBRAUNCCP avatar
Hi Jerry,
I have a similar setup with Esatto/Arco with an Edge 11 and is reduced to F7 1960mm. I have had good results most of the time. I have the primary locked down as best as I can with the standard mirror locks. Usually I have an RMS of around 4-6 when modeling with Mount Wizard 4, and mostly round stars at 300 seconds.
Bruce
Fairly Cold Weather (15 degree Fahrenheit) and Tracking
When the temperature drops to 15F or lower, can tracking be affected? I have a 10Micron GM1000 mount and the stars are looking slightly oval on some subs while others look fine. If temperature is a factor, is there anything to be done with the mount ...
Cold weather tracking affects mount performance; relevant to unguided imaging stability.
Jan 13, 2026
Seeking high focal length telescope recommendations for deep sky imaging
Hello, I have been using medium to lower focal lengths for a few years and wanted to get into the realm of high focal lengths for deep sky. I know that its usually more expensive then high focal length planetary, but I am willing to spend a few thous...
High focal length imaging techniques directly applicable to 2350mm focal length scope.
Jan 23, 2026
Celestron edge hd 9.25 is Perth, Australia too windy for it?
Hi guys. I've started taking interest in some small galaxies etc and i’m pushing the limit of my 683 focal length. I’m looking to get a celestron edge hd 9.25 but wanting to know from real life experience if it’s going to be a waste of money for me. ...
Celestron Edge HD 9.25 performance discussion relevant to author's planned scope.
Nov 26, 2025
