[RCC] Andromeda Galaxy - help with processing
9 replies449 views
Pedro A. Sampaio avatar
A copy of this thread as also posted on Cloudy Nights.
Hello, everyone! This is effectivelly my first real image with my new scope, the WO GT71! I'm interested in constructive criticism (I'm sure there will be plenty) of my new image.
Firstly, things I think needed improvement: the reducer spacing is still no quite right, not sure if anyone would agree - the stars are elongated radially from the center. I however did slightly increase the spacing since then, and my stars now seem mostly fine. Second, a bit of CA, not sure if residual from the triplet (I know even good triplets don't correct 100% of CA), or if it's atmospheric diffraction (the target is always very low - more on that later). Third, the image is very orange tinted - I do like natural color in my astro images, and for sure the center of Andromeda is full of orange-yellow, older stars, but I think it's missing the blueish ring around, which I could not bring out in my post-processing no matter what.
I could only gather 2 hours of integration time, best 60 frames (2" each) out of 64 frames. All frames had good scores in PI's subframe selector. Dithering enabled, stacked in DSS with 2x drizzle, darks, flats and flat darks.
Andromeda is a difficult target - never rises more than 27 degrees, and for the first half of the night, it sits behind the light dome of a nearby NE city. Despite being low, the guiding was very good (for my standards at least) - RMS 1.1 to 1.3", with my imaging resolution before drizzle being 2.5"/pixel.
Processing reutine was as usual:
- Dynamic crop to get rid of integration artifacts
- ABE using a function degree of 1
- gradiant model was very consistent with the perceived gradient
- Photometric CC using standard options (average spiral galaxy)
- SCNR to get rid of green cast (used 1.00 amount)
- Multiscale Linear transform for noise reduction, using a luminance mask to protect brighter areas
- Small stretch using Arcsinh stretch, followed by removing the stars in Starnet
- Further stretching of the starless image, again using Arcsinh.
- Small increase in detail using MLT bias, with a range mask to select only the galaxy and dust lanes
- Slight increase in color saturation of the galaxy using curves, slight reduction in color saturation of the background
- all using the range mask
- Combining the starless + stars image again using pixel math
- Ran dark structure enhance script, 0.3 amount
- Final touches in curves to increase contrast.
My first Andromeda
Any help would be appreciated!
DanRossi avatar
Hi Pedro,  I think this is very good for your first attempt of M31. Sadly I don't think I can provide workflow suggestions because I use Astro Pixel Processor and Photoshop, but I can assure you that this target is not easy to process.  I've reprocessed my version many times.  I noticed that you captured 2 hours of sub-exposures, and I'd recommend doubling that to over 4 hrs. if possible, and I'd also recommend dithering every two frames at least.  If not, you still did a very good job!
Well written Respectful Concise Supportive
Michael Timm avatar
Hi @Pedro A. Sampaio ,
i also think that your image is good. Some things might help you getting even better: ABE should only be used for a first look. Better use DBE. I am mostly following the workflow defined by @Kayron Mercieca here: LVAs Tutorials
Even if you follow another workflow, reading Kayrons tutorials may give you some hints what to improve?
Michael
Gernot Schreider avatar
Hi Pedro,
your data look very good indeed, low FWHM and eccentricity, well done.
I think the color is a side effect of the post-processing. As a matter of fact I also keep learning how to get colors properly, I think it is one of the most challenging part of post-processing.
I suggest that you do indeed DBE _and_ ABE, I always do DBE first, then ABE and each of them twice with division and subtraction.
Then I do a BN to get the colors adjusted, I think this is crucial to do before proceeding witch color calibration.
Before doing any stretching I always check the color balance in the histogram to ensure that the colors are properly aligned. If needed you can apply AutoHistogram to get them perfectly aligned. Only then proceed  with stretching. You  can get a lot of strange effects with stretching if it is not properly done.
I have no experience so far with ArcSin Stretch so I cannot comment on it. I use Masked Stretch.
I also found that doing a little color boost before the stretch helps to get the colors preserved for later. I follow some advice from madratter, see https://astroimages.weebly.com/pixinsight-tutorial.html.
You do not mention any noise reduction process you are applying. I think you need to do that also to avoid boosting noise and with it to spoil the image and/or the color. Please consider some proper noise reduction. The LVA tutorial is a good reference for this or the book by W.A.Keller.
Gernot
David Payne avatar
Hi Pedro,
This is a pretty decent image, especially for first light from astro-photography.  I would play around with curves to adjust the colour (remove some red) and contrast (S-curve) a little more, at this stage.
If I might suggest a way forward - one that focuses on learning rather than producing the "best " image right away.  Keep it simple, and add complexity with time.
I would put away Starnet for now and learn star-masking, stretch with a star mask if you need to - this is sort of a manual masked stretch - after Archsinh  (be careful with black-point on archsinh).  This will give you a sense of how much to stretch stars versus other stuff.  You shouldn't need Starnet or even star masks, really, for Andromeda.  I would use Arcsinh stretch at first, then  use curves along with histogram display to stretch the rest of the way.   Using curves will give you a feel for the data and also give some control over the centre of the galaxy versus the stars vs the galaxy arms.  I know this seems loosy goosy, but it will give you a better sense of the data.
I would also put away Photometric CC (at least, for now) and do some manual background neutralization and colour calibration so you get a sense of what each does, and what limits to place on background versus stars & galaxy.
Try and get your colour balance correct prior to stretching, even if it isn't saturated enough.  Make sure you normalize your individual channels (likely means giving blue a boost with linear fit?).  I dont use SCNR to reduce green from OSC cameras - rather, extract your channels, normalize or adjust contributions with LRGB sliders, and recombine.
I agree with above - are you using any noise reduction?  If you are using filters - use Mure NR, otherwise MLT on linear + MMT, Atrous, or ACDNR in stretched.  I also agree with above on DBE vs ABE in this case - with manual point placement (no stars and off galaxy). -  prior to colour calibration.
You set yourself a high bar for your first image - low in the sky + using a reducer.  (Not a fan of reducers, too much fussing with backfocus)   So kudos to you for producing a great image.
If you save your process steps in Pixinsight and project file, you should be able to return to any point, and change what you do next.  If your colour went wrong, or you created artifacts, you can determine when this occured and go back to that step, fix and carry on.  Just start out simple first and remember there is no single workflow or parameters that always work and there is no single workflow that is "the best".
Cheers and Clear Skies,
Dave
Giovanni Paglioli avatar
Hi!
I personally think this is already a good image for a first light! Subject is framed well, focus semms to be good and also acquisition and star shapes seems OK. Answering Your question is not a simple task or a simple "roadmap to perfection steps" procedure… Instead I make a "simple" question to You: "despite any kind of editing, what You like about Your picture? What You dislike? There is something You would like to see in a different way on the picture? If yes, what? In which way You would like to see that?
Editing is much more related to the experience in "seeing" an image more than "procedures and steps to make" thing.
Let meknow and I will try to help You more!
Engaging Supportive
Thanks for all the replies! Lots to unpack here!
@Michael Timm - Having no background in photography or imaging processing, I learned PI basically through LVA. My workflow is based on it, although I still skip some steps, like convolution - I've tried a few times, but the results were never good. Still, it's been a while since I've read all the tutorials, and I totally forgot he had a step-by-step tutorial for Andromeda!
@Gernot Schreider  - Following LVA's tutorials, I started using only DBE. But I wasn't getting good results with my images, with very wild background models. Now that I think of it, it may have to do that my first targets were either large nebula complexes that took almost all frame (like Rho Ophiuchi) or packed with dense star fields (like  M8 and M20), where it was very difficult to place the background points. I then stopped using DBE and migrated to ABE, using functions of 1 or 2. That gave good results, TBH (see my previous images in my profiles). But I never tried using ABE + DBE, will try it out! Also, I stopped using BN for the same reasons (it was difficult to find a good background model in those images), and Photometric CC did some background neut. Also, never tried AutoHistogram, will check it out!
@David Payne - before migrating to my new APO, I've been using zoom lenses. They don't work well with StarNet - elongated stars and CA meant StarNet would generate terrible artifacts. I used a lot of star masks, before I started using StarNet for my most recent images. I do need to learn a lot, specially with curves! Channel extraction is another thing I never tried.
As for stretching methods, I initially used regular histogram, since that was what I was used to do (I started AP with GIMP). Then tried Masked_Stretch but never got good results (stars were horrendous). I stretched some images with Arcsinh_Stretch and for the most part I liked the results - specially since it seems to preserve color and protect highlights. But I guess the lesson is that each image is different and experimentation is key.
As for noise reduction, I do MLT for noise reduction in the linear phase, and ACDNR right after stretching. I've been meddling with EZ Denoise, with some success.
Respectful Supportive
Christoph Janotta avatar
Hi Pedro,
I think for such low integration time, your image shows much detail. I like how you got the dust lanes to pop.
I love Andromeda and have yet to capture the perfect shot of this beauty. Hopefully the next two months I'll get enough cloudless nights so I can use my new camera on her.
Now to a few tipps:
- As was stated before: DBE. Yes you can't really use DBE on nebulae but on Andromeda it should work much better than ABE.
- noise reduction ... it is always the most "painful" and timeconsuming process, but to get the best result you absolutely have do learn the Jon Rista method as described here: https://jonrista.com/the-astrophotographers-guide/pixinsights/effective-noise-reduction-part-1
Both TGV and MMT on linear data yields so much better results for me, than a single NR at some later point. Especially the inter-stretch ACDNR will help you bring back the blacks tail during stretching. I get so much more contrast when using this method.
Most of the times I can get away with one TGV and MMT on linear data, one ACDNR inter-stretch and maybe a last, very subtle NR on non-linear data.
- I think your stars look great, but you could still try the EZ star reduction script
- you could try deconvolution, local histogram normalization, dark enhance and HDR MT after you extracted your stars with StarNet and only add the stars later, saves some hassle
- Just play around with curves for a few hours. Colors are subjective but you need to get a feel for what CT does. I am sure you can remove the red tint with CT if you play areound a bit.
And lastly, keep the raw data from that session and acquire more subs and come back to the process
Thanks again for the awesome feedback!
I revised my original image, using curves - adjusted to reduce the reds, increased blue a little bit, increased luminance just a tad, and changed the temperature to a colder.
I'll probably reprocess the image in the near future, but probably after I gather more data on this subject.
My first Andromeda
Hi Pedro,
such a great improvement already, well done.
I think digesting all of the good comments will take some time smile
Gernot
RCC - M51, 4 hours from Bortle 5, is there more possible?
Hi, this is round about 4 hours at data, at 450mm reduced with an Apo 80mm f/7 natively. My usual equipment. I shot around 4 hours of data at Bortle 5, and I'm just not content, there's no H-Alpha visible at all (okay I didn't use a H-Alp...
Author seeking constructive criticism on scope images; similar goal and equipment discussion.
Apr 25, 2023
The Witch watching Rigel - suggestions?
I am not happy with this result and I think I know why, but could use any criticism. https://www.astrobin.com/0zrmfg/ This is the Witch's Head and includes Rigel. Most of it was shot from a Bortle 7 location, and the resulting stacks had very, ve...
Author requesting feedback on astrophotography results; directly matches post's criticism-seeking intent.
Jan 22, 2023
RCC - Reducing Bright Stars
In the attached image I find the orange star to the right of the galaxy distracting. To reduce the glare, I did the following: 1. Using GAME, I created a mask of just the three brightest stars, 2 blue and 1 orange, including their halo. 2. I applied ...
Author discusses processing galaxy image; star management relevant to your work.
May 20, 2020
