Can anyone help me out with PixInsight usage?
2 replies251 views
Kayla Kim avatar
Figure 1 shows the problem I'm experiencing, and all that can be determined is that the license has not expired. Some of the information I consulted may have been experiencing the problem depicted in Figure 2.
Figure 2 mentions the solution to the problem and the documentation. But I can't find where it is.
Quinn Groessl avatar
On windows I believe the appdata folder is hidden by default, so near the top you'll need to go to view and make sure hidden items are enabled.
Mine for example is C:\Users\qgroe\AppData\Roaming\Pleiades\ Of course where mine is qgroe yours will be something with your username.
Kayla Kim avatar
Kayla Kim:
Thank you for your help. I'll let you know the results later.
Quinn Groessl:
Well written Respectful
Error in pixlnsight
This is happening to me in Pix. Is anyone else experiencing this, or has anyone else experienced it before? I've been searching for what it could be, but I can't find anything. 📷 Captura de pantalla 2025-12-01 a las 18.02.24.png
Author experiencing PixInsight error; seeking solutions and documentation like source post.
Dec 1, 2025
WBPP experiencing "Unknown exception" errors during "Measurements"
I have been having issues with Pixinsight WBPP failing to measure a significant number of sub-exposures during the Measurements step with the reason as “Unknown exception. I have posted this issue to the PI forum and this time been told to use FBPP b...
WBPP tool failing in PixInsight; likely references same documentation/solutions author cannot locate.
Sep 28, 2025
