Nick Grundy avatar
Was just wondering if someone explained this already...
I  am running darks and noticed a horizontal banding present. I run the asi6200mm through my pegasus ultimate powerbox v2. (both power and data)
I then swapped only the power to a completely separate 12v adapter  from everything else. And the bands were much much lighter. (almost gone,see below)
It's consistent across 2 sessions of darks with almost every other condition being the same.
thoughts on the explanation? Cause?
Helpful Concise Engaging
Gert Eriksen avatar
My guess would be 50/60 Hz hum or a higher frequency noise from the switch mode power supply.
Dark vertical streaks in stacked image
I've been struggling with trying to understand the source of these streaks I see in some recent stacked images. I'm hoping someone here can offer an idea as to what the source is. I'm hoping it's not the camera itself. My set up is a ...
Horizontal banding in darks similar to vertical streaks; both are image artifacts.
Aug 21, 2025
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Fan vibration causes image artifacts; power interference also affects image quality.
Nov 18, 2025
