Help with attaching old Sky-Watcher ED-100 to DSLR
7 replies65 views
bluespeck avatar
Hi folks.  I have newbie question that I hope someone can assist with.
I have borrowed an old Sky-Watcher ED-100 refractor (circa 1980s) and am trying to attach it to a Nikon D750 DSLR.  The 48mm t-mount adapter ring that I normally use with my William Optics Zenithstar 61 (with Flat61 field flattener) does not fit the ED-100.  Can anyone advise what accessories I might need to attach the ED-100 to my Nikon DSLR?
I suspect that the ED-100 isn’t ideal for imaging, but if possible, I’d like to give it a try.  Any guidance would be very much appreciated.
Thanks.
Try a 2" push-fit adaptor with a M42/48 flange. That was the standard those days.
bluespeck avatar
Thanks Andrea.  That is a good start and I'll see what I can find.  Do you know if I will also need a field flattener (or anything else) with this ED-100/D750 combo?
It depends. If you're using the D750 in DX mode then probably not. In FX mode I wouldn't be too sure. I'd start without and see how it goes. One thing you'd need if the D750 is modded (i.e., with the front filter removed) is a IR-cut filter. Also, most likely you would need a minus-violet filter of some sort as the colour correction of EDs isn't great. If you see blue bloating in stars you'd most definitely need one. I'd venture to suggest the Baader Semi-APO which also serve as IR/UV cut.
Stuart Taylor avatar
I (for one) would be interested in seeing a photo of this scope (if you can be bothered). I own a new SW scope and I'd like to see how the old ones looked.
bluespeck avatar
Thanks Andrea.  I am an astro beginner and the info you are providing is very helpful. I really appreciate it.
In addition to a full frame D750 I also use crop sensor D7100, so I certainly have the flexibility to play around and test things out.  Do you think that something like the ELIM-T 2" Prime Focus Camera Adapter (https://bit.ly/2WOMPJo) would work (and is this what you meant when you suggested a 2" push-fit adaptor with a M42/48 flange)?
Neither camera is modified and I have been hesitating to do so as a CCD is on my wish list and a probably purchase early next year. In the mean time I have just been using an Optolong L-Pro light pollution filter.
Respectful Supportive
bluespeck avatar
Stuart Taylor:
Hi Stuart.  Excuse the mess in my office and all the stuff in the background... Here is a quick pic of the old ED-100.  It is a borrowed unit and didn't have a dovetail bracket or any parts to attach the scope to the mount so I've temporarily MacGyvered something using parts from another rig.
The Optolong L-Pro should be fine. As well as the prime focus adapter you mentioned above.
ASIair & DSLR: Advice re saving to FITS vs native DSLR formats
I have a newbie question and hope someone can assist… I am using a DSLR with an ASIair Plus and have a question about file formats. I have the ASIair set up to save one copy to its internal storage and one to my DSLR’s SD card. The copy saved to the ...
Discusses DSLR imaging setup, though focuses on file formats rather than mechanical attachment.
Feb 12, 2023
DSLR and narrow band imaging
Hi all, Looking for some help, I am very new to all of this (3 weeks in) and sometimes it is really difficult to see through all of the info available online. My setup is a skywatcher Mak 127 with a focal length of 1500mm, a skywatcher EQ5 pro goto m...
Help attaching telescope to DSLR camera relevant to author's setup.
May 22, 2020
