Flat panel. So much intensity for a 2600MC
12 replies422 views
Julio Maset avatar
I took my first light with the Askar FRA 500 and a 2600MC pro on last weekend . When I tried to take the flats I observed that my flat panel is excessive. At 40% of the histogram the exposure time was 6ms, so far from the 2-5s I wanted to obtain. So my question is if you know a dimmable panel that can dim the light enough to reach that exposure of 2-5 s or at least 1s. Thanks in advance
Nick Smith avatar
I use a flat panel and then put 1 or 2 sheets of white photocopy paper between the panel and the scope, that has the effect of increasing the exposure time.
Jeff Reitzel avatar
I use an Alnitak Flip Flat with mine. All my LRGB and Oiii Flats are 6s exposure targeting ~18-20k ADU. Ha and Sii flats are 15s targeting ~8-10k ADU.  That works well for my QHY268M. The Alnitak Panel seems a bit weak in the Red spectrum so my OSC flats are a bit more challenging, especially with dual NB filters, but still easily managed with similar exposure times. I have also heard good things about the Deep Sky Dad panels.
Jeff
JORDI ZAMORA avatar
You can also put a neutral density sheet like these
https://www.amazon.es/dp/B0CPLPGT1N?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Oskari Nikkinen avatar
No need to expose for so long with flats when using an IMX571 sensor.
My flats are 9.3ms at the moment and work perfectly, so you have nothing to worry sbout here.
Concise
Oskari Nikkinen:
*That cannot be stressed enough. There is NO need for these overly long expsoure times!
Julio Maset avatar
Thank you to all of you for your advise!!!!
Great forum
Brian Diaz avatar
Hi
my flats  for zwo 2600mm  and 6200mm
3s , and  ADU 24K to 25k with pegasus masterflat
note : for LRGBSHO
CS, Brian
Julio Maset avatar
Finally I bought a PWM module at AliExpress. Setting it at 3% in amplitude a s 24Khz freq allows me to obtain flats of 2" at 40% of the histogram.
ScottF avatar
You only need long exposure times for a sensor like the asi294 series.
Julio Maset avatar
In any case I obtain histogram's values about 40%. Using the PWM module I can vary all the parameters (amplitude and freq) to play with exposure times maintaining the histogram at the ADUs I want.
Pedro Goles avatar
I have an homemade flat panel with few blue LEDS and several incandescent normal car bulbs (all 12V), with many covers of paper and acrillic. The amount of light for my QHY 268M CMOS is really small, but  for  luminance filter it's huge…I did an experiment with lesser exposure times but even at times <1 second it saturate the sensor.
So I tested taking flats with the front of the scope covered (light zero) and discover the sensor still have some signal (!)  but the flats were too dark and useless…
At last I go the opposite way and give more exposure times, about 2 seconds for luminance, 4—11 sec for red-green-blue filters and about 30 sec for narrowband filters, as an old flat box I made that works well with my last CCD.
Today I'm using the times commented here, regardless the saturation (high ADUs) of the sensor, and surprise…these work fine !
Pedro
Ed Astle avatar
I bought an RGB ceiling light. Pushed it up tight against my Celestron C9.25 and what came out of the rear was dim compared to the brightness at the front.
I'm guessing the 90 degree dispersion LEDS in that "panel" don't go down well with an F10 scope. Ho hum - only £20.
However, the fact these RGB ceiling lights come with a remote control allowing you to cycle through red, green and blue interested me. Or you can select colour temperature from 3000K - 6800K.
But it made me think. I've got LCD screens for computers. I've got an OLED TV. These could all be possible "light panels" staring me in the face.
I could just as easily create R/G/B images in Microsoft Paint (free!), display them on the monitor or TV, and use those.
I tested my OLED TV + IMX585(colour) camera. I was able to detect infrared 800nm+
I removed the protection filter from the cam for this test. 585 = STARVIS and they should all have good IR response - if allowed to see it…
Before you rush out to buy a panel, maybe the one staring you in the face will do.
Regards, Ed.
Flats undercorrecting vignetting
Hello all! I'm facing issues trying to calibrate my light frames with flats, they seem to be undercorrecting the vignetting on the frame: The equipment I'm using is the following: - Modificated Sky-Watcher Quattro 250P OTA - Sharpstar 1x GPU ...
Flats issues may relate to exposure problems with flat panel setup.
Aug 6, 2025
Over correcting flats with fix
Howdy all. I've been rather bummed with the quality of my images for the last 9 months. I have data collected for two projects that I never finished due to the poor quality. Recently I discovered that my flats were over correcting my LRGB images ...
Flat quality problems could stem from incorrect flat panel exposure settings.
Aug 17, 2025
