Kerry Werry avatar
So I'm a refractor guy who wanted more reach so I bought a used iOptron RC6 with an upgraded Moonlight manual focuser. I've just got it and am trying to reach focus and failing miserably … I've tried every combination of the main extensions with no joy. Trying with a ASI 533 camera with the standard 55mm rings…. Could it be THAT FAR out of collimation. I'd rather not start playing with the collimation if I don't have to..
Am I missing something stupid? I've been trying this during the day on far targets and not even getting close to focus..
Is there something else I should be looking at since the scope was shipped cross country (no damage to box or packing)..
Thanks for the help!!
Kerry
Respectful Engaging
Stephan Linhart avatar
Hi Kerry
You need the three M90 spacers that should have been included with the scope. Then you need another maybe 20mm. This depends on your focuser.
The three spacers have a total length of 100mm,
Regards,
Stephan
Nicolas Godingen avatar
Before playing with focus you need to check this, with the original focusser from the 2" connection you need to have 159mm to achieve the backfocus …. so if you stack the extensions you deduct the distance you stacked to this 159mm, then you should be able to achieve focus.
Kerry Werry avatar
Just to close the loop on this I did find focus at about 263mm and had a quick first light under poor conditions, but it went well and I did also manage to do a star test for collimation and it was spot on which was great since the scope was just shipped to me across Canada via regular post. So now I just need to get some good conditions and get out imaging as I have a pretty good list of targets I want to try with this scope.  Thanks for the help!
wizzlebippi avatar
Take a sub against a dense star field and plate solve it.  I suspect you're well off the nominal 1370mm.
To adjust this, use the knurled ring behind the secondary mirror to adjust the spacing.  Outward/forward is shorter focal length and inward/backward is longer.  The ratio is about 10:1, meaning you change focal length roughly 10mm for each 1mm of secondary mirror travel.  Hold the secondary mirror housing and loosen the knurled locking ring.  Then spin the secondary mirror in the appropriate direction.  Rinse and repeat until you're within 10mm of 1370mm.
You should only have to dial this adjustment in once.  This may throw off your collimation, but that's fixable as well.
Well written Helpful Concise
External focuser on an SCT; What about temperature change induced focal shift and back-focus?
It seems like every serious astro-photographer is putting external focusers on the back of the EdgeHD telescopes and locking the mirrors. I picked up a nice little EdgeHD 8" and a Primaluce Lab Esatto 2" LP focuser and gave it a try myself....
Discusses back-focus issues with external focusers on telescopes similar to yours.
Mar 25, 2026
Clear Skies
Living in northern Orange County, CA under the light dome, I recently became infected with an overwhelming desire to capture multi-million year old photons and I haven't been the same since. I've lived all over the world, to include quite a f...
Author has modified Newt; RC6 discussion may offer alternative telescope perspectives.
Apr 4, 2023
Brand new Ritchey Chretien Optical Systems scope
This is just something I wanted to alert people to, it is not my scope and I have no connection whatsoever. I am not sure if I am violating any rules and I apologize in advance if I am doing so. Please just delete the post if necessary. In any case, ...
Author owns RC scope; post discusses RC6 ownership experiences and advice.
Dec 7, 2022
