Dan Brown avatar
Hello all. I have an issue that arises every so often. It happened last night about 3:00 a.m., PHD2 lost pulse guiding to my mount. PHD continued to run and show the guiding graph but no corrective pulses were sent to the mount. I had to restart PHD2 and NINA to correct the issue. My feeling is that it may be an issue with PHD2 since it will become unresponsive at times during these events.
I use a Mele Quieter 3 on my scope and wirelessly connect to my 10Micron mount. I control the Mele with a laptop wirelessly connected to the 10Micron mount as well.
Does anyone have an idea of what is going on, or a fix?
Thanks in advance.
Dan
Well written Engaging
SkyHoinar avatar
Hello Dan,
Maybe not the same issue, but I share what I have:
The wi-fi of my mount could not keep up with the data traffic, even if it worked very well for months. I also have a MeLE which was connected to the wi-fi of the mount and so was my laptop via remote desktop. The issue started suddenly one night when the remote desktop session froze completely. Restarting did not solve it.
At the end, I had to connect my laptop to the MeLE directly via a hotspot open on the MeLE and not through the wi-fi of the mount. In my case it solved the issue (however still not clear why it worked before and all of a sudden it stopped working).
I hope it helps.
Tobiasz avatar
Did you check your power management settings in Windows? I assume your Mele is running on Windows 11 (like mine)? In Windows, you even have to check the hardware adapter for power management settings which allows Windows to shut down the device. I deactivated everything.
Maybe you can look into the event viewer for unusual behaviour around your time it happened. Same goes for phd logs around the timestamp.
regards
Dan Brown avatar
Tobiasz:
regards
Good advice, I will look into those suggestions.
Thanks,
Dan
Well written Respectful
Ron avatar
Dan,
Please post your findings if you figure out how to correct the issue.  I have the same error message from time to time.  I'm using a Paramount MYT and get the same pulse guiding error message, even though the Paramount is using DirectGuide.
Ron
TiffsAndAstro avatar
Dan Brown:
Thanks in advance.
Dan
Total guess but check your usb cables and hub etc.
A meridian flip or slew might be enough to jiggle one lose connection
Mini PC crashing caused scope to hit mount
Looking for some help/advice please, on how to understand what caused my mini pc to crash & also how to stop the mount continuing to drive in the event of a pc hanging-up.. Following a recent imaging session I awoke to find my mount (an EQ6-R) ha...
Mini PC issues could cause PHD2 unresponsiveness and loss of guiding pulses.
Mar 11, 2026
Paramount MYT + Nina + PHD2 guiding issues
Hey folks, quick question for anyone running a Paramount MYT with NINA and PHD2. My Paramount is doing my head in. Everything is set up correctly as far as I can tell, SkyX, ASCOM, all that. But every now and then PHD2 throws up the error “your mount...
Direct experience with PHD2 guiding failures using similar software stack.
Nov 27, 2025
Qhy290mm disconnection from phd2
Is anyone using a qhy290mm for guiding I had used this camera for ages for guidIng via a usb 2 cable with absolutely no issues , then a little while ago it started playing up disconnecting using phd2 whilst guiding now I’ve tried connecting using a p...
PHD2 connection issues similar to yours; troubleshooting guidance camera disconnection problems.
May 3, 2023
ASCOM.DeviceHub running unstable
Is anyone else experiencing an unstable connection with the ASCOM.DeviceHub Server? I'm using an old and modified Zeiss 1B mount with an FS2 controller that communicates via the LX200 protocol (specifically, the AdvancedLX200 Version 6.4.02). To ...
PHD2 issue or hardware? — involves PHD2 and mount communication problems.
Feb 27, 2023
Guiding Issue
Recently I disassembled my HEQ5 for lubrication and bearing replacement. However, after putting it back into operation, the guiding is not behaving as it should. Without guiding, in 120-second frames, about one out of every five shows a star trail. B...
Guiding malfunction diagnosis after equipment changes; relevant troubleshooting approach.
Nov 12, 2025
