Javier Figueroa avatar
Hi guys, I’ve been trying to get my hands on a AG optical 10” IDK used since AG is not producing any more products but they are a rare catch.
Any recommendations on a scope at the same level? I’ve been looking at the GSO/ Ioptron/ Apertura 10” RC but I’m not sure they have the same quality, they are also slower, any suggestions on something else at the same size so I don’t have to upgrade my ioptron 70G. I currently own a 9.25 HD but I’m getting tired of mirror flop and will like to upgrade since I’ll be having it installed on a remote observatory, any suggestions will be appreciated it.
Thanks and clear skies.
Ani Shastry avatar
A PlaneWave CDK 12.5 should be the closest match, albeit the debacle with the EFA and the Delta T will put it further north in terms of price. Have you considered keeping your EdgeHD 9.25” and getting a Moonlite Litecrawler or an Optec Hercules to focus and just lock the primary mirror?
Hi Shastry, thank you for spending the time, I have considered that option, the only problem is that I have no space for it between the rotator, AO unit, off axis, filterwheel and camera I’m tight, only have like 12mm left for adapters. The CDK 12.5 is a beauty but like you said it will get pricey, I will also have to invest on a new mount which I’m trying to avoid, no many options out there I guess.
Ani Shastry avatar
The moonlite litecrawler and/or optec hercules have the rotator functionality built in, so you don’t need an additional rotator.
The hercules for example occupies 50.5mm of backfocus, leaving a reasonable 95.55mm of spacing. What is the backfocus consumption between your AO unit, OAG, EFW and camera?
Ani
psparkman avatar
You might check out CFF Telescopes.  I noticed they are making a 250mm RC with a corrector.  It uses GSO mirrors, but their mechanics which look pretty nice.
Patrick
Hi Ani,
I attached a picture with measurements, if I end up using the Hercules I’m going to have to sacrifice something else.
Bill McLaughlin avatar
You could gain a bit by going to an Indigo guider. They are a few mm thinner. You might gain a bit as well by having a shorter Focuser to AO adapter made.
Thank you Patrick, I will definitely take a look at them, I appreciate the response.
Javier
Hi Bill,
thanks for the response, yeah the indigo can definitely save me some space, in reference to the AO unit, I had an adapter made as short as possible, honestly don’t think I can get it shorter, I will work out some numbers with the indigo to see If I can make it happen,
thank you
Daniel Carter avatar
If you can get one and have enough mount, the 12.5" AGOptical iDK is much easier to collimate.
Hi Daniel,
I’m trying to avoid spending more money on mount, but yeah that would be Ideal, so you think the AG 10 is difficult to collimate?
Javier Figueroa:
Hi Daniel,
The owner Dave Tandy told me that the 10" was harder to collimate than the larger scopes and I've read the same online. I think you have to remove the baffle tube completely in order to collimate on the 10". The larger scopes can leave the baffle installed if i recall. I don't remember having to remove the baffle on my 12.5".
I was able to get my hands on a AG IDK 10” and it’s a piece of art, I’m almost done setting it up to be dropped off at a remote observatory, so far I’m very impressed with the build quality and looking forward to first light. Thank you for all the recommendations
CS.
Discusses mount compatibility with telescopes similar to author's upgrade needs.
28 days ago
Secondary mirror coating issue or possible light leak problem?
I was considering sending my secondary for my ago idk 14.5" over to terry at ostahowski optics for a recoat because if I look closely enough, I have what looks like an oil spot or something that slightly dulled a small part of my secondary coating th...
Addresses AG IDK telescope maintenance; directly relevant to author's AG interest.
Nov 3, 2025
