Using a doublet for mono imaging?
5 replies246 views
Photon_Collector avatar
I have the Zenithstar 61 small refractor from William Optics. I will send my bigger Askar 120 to a remote observatory with a OSC camera, and would like to buy a mono camera to use from home (light polluted) while my better rig is imaging from Bortle 1.
I've heard doublets are actually good for mono imaging, anyone have experience(s) they can share?
Yes, you certainly can. I've done a lot with a cheap ST-80 doublet using dual band filters and a relatively small sensor camera (585). Shooting mono would work even better as you don't have to deal with the different best focus points you get with dual-band OSC.
Oscar H. avatar
if you don't take luminance and you had an achromatic scope (single element, worse than doublet), and if you refocus per RGB filter, you can get away with no CA (because CA comes from R, G, B focus points that vary from each other a little)
Charles Hagen avatar
That is a wildly inaccurate oversimplification. Red, Green and Blue all are ranges of wavelengths that can all experience CA within their respective band passes. Even if you are shooting narrowband which is effectively a single wavelength that will not experience CA, your singlet will likely not be optimized for that wavelength and you will get other extreme aberrations. If you are looking to take nice images, a high quality doublet can be fine for narrowband, but I would not recommend anything cheap. There are many other considerations to be made beyond the number of elements in the scope.
Oscar H. avatar
Charles Hagen:
thank you for correcting me
Taman avatar
I have the Zenithstar 73 and have successfully used it for narrowband. Provided your stars look reasonable with a colour camera, you should have no problems with mono. Here's one of my better examples:
https://www.astrobin.com/0fue8u/C/
Well Written Concise
Advice on Next Upgrade
Hi AstroBin community. I am an amateur astrophotographer looking for some advice as to what I should upgrade next. My current setup is: ZWO ASI533MC ProWilliam Optics New ZenithStar 61 IIWilliam Optics New ZenithStar FLAT 61AOptolong L-UltimateEQM-35...
Discusses camera selection for astrophotography setups and upgrades.
13 days ago
Antlia Dark Series LRGB Pro Imaging Filter Set - 2" Mounted - anyone using?
Is anyone using this particular filter set under dark (Bortle1-3) skies? Our remote imaging group needs a new 2” filter set and the Antlia has nice overlap between R, G & B. I have heard many complaints about Antlia filters having bright star hal...
Addresses imaging filters for dark sky remote observatory imaging setups.
Dec 31, 2025
