SHO + RGB stars
3 replies207 views
Roberto Testi avatar
is anybody aware of a good tutorial explaining how to merge SHO data with RGB data for stars? or is anybody willing to share his workflow on this subject  in some detail? thank you!
Quinn Groessl avatar
To be specific depends on what program and any plugins you use. To be general, first make sure your RGB and your SHO image are aligned and cropped the same. On your SHO image Gradient correction, color correction, deconvolution, noise reduction, then star removal and toss out the stars image you get. After that stretch your SHO image and do whatever you want with it. With your stars image do the same thing, except keep the stars and toss out the leftover image. Then sometime once you have your SHO image the way you like, combine your stars and you've got your image.
Dale Penkala avatar
@Quinn Groessl has the just of it, but to add its going to depend on what software your using. I do not use Siril so I can’t comment on how that software is able to combine 2 images or if its even possible.
In PI once you have your starless image of the object. Name it “starless” and once the star layer is processed name it “stars”. In PI use PixelMath and use this formula: ~((~starless)*(~stars)) and run the process. When I use it I always check mark “create new image”
Dale
Concise
firstLight avatar
@Roberto Testi  and @Dale Penkala
There are 2 or 3 options to recombine several "channels" to a final image with Siril alone:
1. Menu "Image Processing > Star Processing > Star recomposition"
Here usually a starless (select it for the left side) and stars image (select it for the right side) can be recombined with a whole lot of stretching and overlay parameters. But you can combine whatever you like.
2. Menu "Image Processing > RGB Compositon" or "... > Merge CFA Channels"
3. Menu "Image Processing > Pixel Math"
Select and recombine up to 10 (I believe) Images with the full power of PixelMath
Good luck and clear skies,
Frank
Stacking multi-telescope imaging data with different focal lengths and sensors
Hi everyone! 👋 I have a question for the DSC team (and anyone working on collaborative imaging projects). If you’re willing to share, I’d love to learn a bit about how you approach stacking data from different telescopes and setups. For example, comb...
Addresses merging data from different sensors and imaging setups.
21 days ago
[RCC] SHO M16 Current Version and Narrowband Processing
I’m still working on narrowband imagery processing and would appreciate any comments you have on my current version of M16 or the workflow below. My goal here was to get as much detail and brightness as I could in the “jewel box” outer nebula while r...
Directly covers narrowband (SHO) processing workflow and techniques.
Sep 20, 2025
