Best way to share PixInsight master stack to Astrobin communiuty
Support requests are handled via the support form so they can be tracked and resolved properly. This section is for community discussions about the AstroBin platform.
deleted avatar
Hi Folks,
As the subject line states, what would be the best way to share master stacked image from PixInsight to the Astrobin community??
I wasn't sure if just attaching the masters to a discussion topic would be suitable, or to setup a shared google drive with a link…
Also I'm currently going back to old data and re-processing them as I learn more with PixInsight… for a image that I've already uploaded, and re-processed do i just upload the new image as a revision to the previous one?? or can I delete the orginal and upload the new??
Thanks
wsg avatar
Salvatore Iovene avatar
AstroBin doesn't currently offer to host your raw data, unfortunately. If you have Ultimate, you can attach a single file (XISF, TIFF, PS2) to your image using the "Actions" menu and "Upload uncompressed data source". So I would say the best way is to use Google Drive or similar and just share the link.
Also I'm currently going back to old data and re-processing them as I learn more with PixInsight... for a image that I've already uploaded, and re-processed do i just upload the new image as a revision to the previous one?? or can I delete the orginal and upload the new??
AstroBin recommends the etiquette explained here:
https://welcome.astrobin.com/features/image-revisions#faq
But it's not enforced.
@wsg mentioned the IOTD/TP rules, which enforce not uploading and submitting a new image if it's just reprocessing of old data.
Hope this helps!
Salvatore
deleted avatar
@Salvatore Iovene
Thank you sir... I will review and follow as recommended
WBPP interactive frame selection: tracking included frames for Astrobin uploads
I used the new interactive mode for frame selection in WBPP and it works great. It is easy to see what should be rejected in your light frames and what to include. It saves the hassle of getting into SubFrameSelector and making a copy of the selected...
Discusses frame selection and Astrobin uploads, directly relevant to sharing processed images.
Feb 1, 2026
