New rotator: I need some advices
5 replies171 views
Leonardo Landi avatar
Hi guys. I'd like to add a rotator to my setup but I need some advice. Due to the short OTA, in some positionsof the filter wheel hits the mount. Rotating the camera manually this is not a problem because I can use the upper arch and get all the angles I want, but with a rotator I'm afraid it could become risky. So I would like your advice to understand if there is a rotator that allows you to set limits by working only in a certain range of angles. An alternative would be to make new spacer blocks between the rings and the Losmandy bar of greater thickness, but I would avoid it if I could.
Xenofon Nastos avatar
Rotators usually allow to set specific limits to rotation. I have a rb-focus Camelot 2" rotator with an ASCOM driver in use and it allows to set the limits and even the way of rotation (clockwise, counter clockwise, bidirectional…).
Xeno
Quinn Groessl avatar
It's possible with a rotator you might have to slide it back enough that it clears. Thicker risers between your scope rings and your dovetail looks like it would solve the problem too.
Quinn Groessl:
I hadn't thought about the shift in the center of gravity due to the weight of the rotator. Thicker risers could be the simplest solution, also because I make them myself on the milling machine like the cable glands for cable management. But I would have to disassemble everything. I would avoid it if I could, if there is a safe way through software management.
Stjepan Prugovečki avatar
If the mount payload specs allow, kind of a simplest solution could be adding some weight to the front (below your blue cable box). That would let you to pull the whole setup back just enough and still remain balanced.
Leonardo Landi:
Quinn Groessl:
I thought so when I saw the raw aluminum. I made my own risers for my last scope too. And now that I'm thinking about it I'm stupid, because if anything adding the rotator would make you move the scope further forward, not backward like I said.
Different filters - different distances - different rotation angles
Hello, everyone, I like to use the NBZ and NB3 for my narrow band subs. Since I'm shooting in a Bortle 5 zone, I use the Baader Neodymium filter (Moon and Skyglow) for the RGB shots. The IDAS filters are 2.5mm thick, the Baader filter 2mm. Since ...
Filter wheel positioning issues relevant to narrow-band imaging setup constraints.
Nov 25, 2022
I would appreciate some general gear advice from experienced people...
Hey all, firstly this community seems excellent. A lot of people and a lot of knowledge. So, I was hoping I could get some general advice here. I’ve been very interested in space since I was a kid. The subject of Astrophotography always seemed too ou...
Seeking general gear advice from experienced community members about equipment setup.
Jan 26, 2026
