Big scope fever. Is big aperture only emptying your wallet?
AnderlArun HTony Gondolaandrea tasselliTimothy Martin
75 replies3.2k views
Anderl avatar
Hello and good evening fellow astro friends,
In case you are asking yourself why anyone would say things like i state in the title of this thread. —> mr. Timothy Martin here on astrobin is the answer. He and a lot of others to be honest.
the first picture here is a very recent image of the day taken by wolfgang promper with an huge 600mm asa telescope. Stunning picture. https://www.astrobin.com/g16lhp/
The next one is taken by timothy martin with an 130mm apo telescope  https://www.astrobin.com/fpu4ye/
both are great looking pictures taken by professional astrophotographers with expensive scopes and under good skies.
i would say the asa shows slightly more detail but the difference is very small and after all that talk here on astrobin that only aperture matters i am somewhat entertained by the fact that i can only say it doesn’t (not to the point it get talked to). It is just ridiculous how overblown this whole aperture thing is.
thank you and cs
andi
Christian Großmann avatar
Hi Andi,
it's not just picking two images of different guys to compare them. There's a lot more to it than just the aperture. One big thing is the knowledge of someone if it comes to image processing. This is a huge thing and maybe the second important one. But lets say both guys did process their images on the same level, then to me the first one taken with the 600mm scope is much better than the second one. If you print the images on a 10x15cm (4x6") paper, you'll hardly see any difference. But print them on A4 or even A3, the first one stands out by a huge amount. To me, the quality is night and day. But it has to be, because assuming perfect conditions, the details you can get is dependent only on the aperture.
Sorry, but I don't agree with you. Is it worth the money? This is a question everybody has to answer for themselves. I leave this to you…
Christian
Lee avatar
Slightly?  The difference looks significant to me.  I had to check you didn't have a joking emoji
There is a vast ocean of difference between the two and no offence to Timothy, which is still a gorgeous image (the image, not Timothy although he might be as well…). Or it is just trolling?
Anderl avatar
There is a vast ocean of difference between the two and no offence to Timothy, which is still a gorgeous image (the image, not Timothy although he might be as well...). Or it is just trolling?
No trolling. I think the differences are very small for the aperture difference of an 130mm and an 600mm scope.
Lets assume diminishing returns moving up further using bigger (earth based) scopes. If that is how close a 130mm apo will bring me to an 600mm scope, how far away can a 10inch or 12inch scope be?
Tobiasz avatar
Is this a rage bait thread? Both images are beautiful but you can see it crystal clear that Wolfgangs image has much more detail, and more detail is resolved through more aperture. Who would have thought? If your sky supports it go BIG.
Erlend Langsrud avatar
There is clearly a rule of diminishing returns here. Especially if the goal is to take aesthetically pleasing pics. The pic from the big scope is not 4 times better. But it is better.
The images look similar at first glance, but there is much more fine details in the image from the big scope.
Ashraf AbuSara avatar
The difference is like 1080p vs 4k. It is quite significant. Not sure why you don't think so.
That being said it is insanely impressive what Timothy got out of only 130mm aperture refractor. The TOA is very very sharp.
Alex avatar
Timothy has the same 130mm scope as I - so by default I like his pictures :-) and his processing skills.
but have to agree on the earlier comments, not a comparison and not at all to compare is the light gathering power.
there are lot very good software tools out these days improving picture quality and sharpness but still the asa collects over 20 times (!) more lights than the 130 mm.
without the intention to open this „pandora box“ a good quality 130 mm refractor can easily stand a comparison with an 8“ or even 10“ reflector in terms of details and contrast but the refractor then normally is the way more expensive option in this comparison.
but not to compare to a 600 mm scope.
Alex:
Which you just did. And of course, not.
Alex avatar
 In the context I have to admit that I can’t wait bringing my 14” Newtonian to my spot and start imaging with it.
Oskari Nikkinen avatar
Alex:
*I think the box is already wide open so i'll bite.
If both the 130mm and a 200mm or 250mm are given the same amount of time to image a target that fits in the field of view of all these scopes, then the biggest scope wins - this is non negotiable.
And i do think its fair to give each scope the same time limit, since we cannot choose our clear nights and have to work with what the skies give.
In the end the only thing that matters is the number of object photons that hit the scope, which is of course determined by the size of the aperture.
Sure i moved the goalposts a bit by saying that we are imaging a target that fits all 3 example scopes field of view, but even if not we would have the same image faster by mosaicing with the larger scopes so the point still stands.
Helpful Insightful Engaging
Anderl avatar
Alex:
Would you mind showing me a picture of the trifid taken with an 10 inch scope showing that much more detail than the 130mm scope that you feel „and of course not“ is the right answer to this?
Arun H avatar
Oskari Nikkinen:
I agree with this and this is a point that I keep bringing up in discussion after discussion. Aperture (and for a given integration time, ONLY aperture) determines how many photons you gather from a fixed area of sky. The only thing I would add is that the resulting images have to viewed at the same viewing resolution and FOV.
As an aside, the person I have learned the most from is John Hayes, and here is his wonderful presentation on the benefits of large scopes (which I do think this comparison supports):
https://www.youtube.com/watch?v=HiJoqQp1qFI
That's a trifle more involved, isn't it? You want to compare them side by side not "some refractor" there and "some other reflector" elsewhere sometime else. That's the bare minimum basis of any meaningful comparison. But there is more to it, I can guarantee that.
Anderl avatar
No. Just show me a picture of 8, 10, 12 or even 14 inch scope that shows an „and of course, not“ answer more of detail compared to the toa 130 here.
I agree with everyone above, the 600mm image is clearly the winner in terms of detail and resolution. Look carefully at the lower left corner, there's a world of difference there. That's said, the difference isn't as great as one might suppose from just aperture alone. You have to remember that the seeing is a great leveler here. If these two telescopes were in space the difference would be much greater, but they are not. Large apertures in this size range will always be limited by the seeing. A 600mm scope in theory can resolve down to about 0.20 arc/sec. when was the last time you saw seeing that good, my guess is never. You're taking that starting resolution and putting it through that low pass filter we call the atmosphere and most of the damage happens in the first 1/10 of a second. If both of those scopes had imaged the Moon or Jupiter, the difference would be night and day, no comparison. That's because, unlike deep sky, lunar and planetary imaging techniques allow you to go a long way to recovering the actual resolving power of the aperture, given good enough seeing. These techniques are not yet applicable to deep sky/long exposure imaging. If they were, you'd be totally blown away with what the large aperture can deliver but we're not there yet. With larger apertures in deep sky imaging, you can and do get better detail but the main advantage is in the light gathered. The brightness of an image on the sensor at F/4 is the same, regardless of aperture but the 130mm f/4 will be imaging at an EFL of 520mm, the 600mm will be at 2400mm. This delivers a much larger image at the same brightness.
I won't do any such thing. I know what I know and that's enough for me.
Well written
THIBAUD Lucas avatar
Hi Andi, how would you scale the detail level between those two scopes? there's is a different amount of sharpening applied, maybe some HDR treatment also.
But if the sensor is suitable you wil get more details for sure that's just math.
If you take Rayleigh or Dawe's formula there's no point in discussion.
Smallest detail resolved with Dawe's
TOA130: 0.89 arcsec
ASA 600: 0.19 arcsec
I live in the same skies as some Wolfgang's telescopes, seeing on average is 0.5" but drop down to 0.2" of course in a "normal" skies such diamater will resolve as much as the sky allows…
On a philosophical point of view it's up to you where your expectations are and I totally respect your point of view of not seeing the point of going big. but I invite you to check one raw files of both under the same sky, it will be for sure obvious which is which even between a 12 inch and the TOA.
YingtianZZZ avatar
The first one looks much more sharper than the second one. The sharper edges of colors, edges of dark area, fainter dark clouds. And for myself, I'm getting apertura fever and just do binning,it's much faster.
Timothy Martin avatar
I'm flattered to have any image of mine compared favorably to even the worst image Wolfgang has ever taken. But I have to agree the Wolfgang's image is far better. And he got his superior shot in half the time I got mine. When it comes to telescopes, it's definitely the size that counts. Wolfgang is also in a different league from me when it comes to knowledge and processing skills.
I'm certainly no professional--just a retired unfrozen cave-man lawyer with lots of spare time to mess with astrophotography. Still, I'm ecstatic over the results the TOA delivers. It's damn sure the best scope I've ever used. It will never deliver the same results as a great 24" or 1.5m reflector, but I couldn't possibly be happier with the results it gets.
I'm pretty certain, however, that there is a point of diminishing returns for people on a budget. I spent the first couple of months of the summer framing up the Crescent with all my scopes and compared the results. This is a totally informal and unscientific comparison. I'm well aware that there are many variables here I didn't even try to account for. The only question it really answers is, "What can a rank amateur like me with less than five years' experience get from different telescopes on one particular target shot in roughly the same way using similar processing steps?" Frankly, I was astonished at just how close the RedCat and the FSQ came to the CDK.
The CDK's results were much better than the RedCat. And I don't regret getting the CDK. But it gives me great pause when I consider investing well over $100k on a CDK24 parked in Chile. For the same money, I could place copies of all three of the scopes (CDK12, TOA130, and FSQ 106) I have at Deep Sky West down there. And I would likely have fewer issues with those three scopes than the one big one. I don't know how many more trips around the sun I have left. And my personal goals are more artistic and outward facing than they are scientific. So right now, I prefer the wider fields. And I intend my images to be viewed primarily by people who otherwise have no interest in astronomy--not pixel peepers who are going to examine every star at 50X native resolution and feel compelled to tell me how overprocessed my image is.
So while I certainly acknowledge the superiority of a larger aperture, its importance for certain tasks, and its value to some people, my Schwartz is about as big as it's ever going to get.
John Hayes avatar
I've asked a similar question about aperture...and I've explained it in some detail here:
So...if you want an answer to why big telescopes might be better than small telescopes, watch this video!
Kay Ogetay avatar
Timothy Martin:
I was going to refer to your results and I definitely second your opinion. As a RedCat user, I like to push its limits. I do not think we overestimate the big aperture, but I believe we underestimate what can be done with smaller scopes.
FloridaMac avatar
A large aperture is not “better”, it just has different attributes. There are some who only focus on wider-field objects, so a larger aperture is not necessarily “better” to them.  Can you approximate a larger aperture image with a smaller one? Depending on the situation, sometimes you can. It really depends on variables such as the quality/speed of the glass, alignment, camera quality, guiding, hours of data, post processing, etc.  Under strict apples to apples, a larger aperture can collect visual data of a smaller piece of the sky, but to say that is better depends on the perspective. There are use cases for different apertures just as there are for cameras, eye pieces, etc.
Arun H avatar
While this is technically true given certain constraints, there are real and practical advantages to aperture. Assuming seeing limitations such that the large scope has no resolution advantage, and assuming the same sampling in object space (essentially the same as my previous comment of same viewing resolution), an 80mm scope will need 6.25 times the integration time to achieve the same signal as a 200mm reflector (neglecting the loss due to the central obstruction). A 20 hour image on the 200mm - a reasonable imaging time - becomes a 120+ hour image with the 80mm. So, while yes, it is theoretically true, real and practical limitations arise. The other problem with small scopes in light polluted areas is complex gradients that need to be managed with very long integration times. There is a better chance of avoiding those with scopes that collect signal quickly.
Sky Rover 50 SAW review
I have been searching for a telescope with the shortest focal length, the largest aperture possible, and which would work with a full-frame sensor. My first one was RedCat51, which was quite OK, but I wanted something shorter. I found Askar ACL200, w...
Discusses telescope specifications relevant to astrophotography equipment selection criteria.
Feb 10, 2026
